Install on 64 bit machine?
- sam2004
16 Dec 2022 23:51 #259687
by sam2004
Install on 64 bit machine? was created by sam2004
Will the Live/Install CD on this page linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html work on x64 machine? Will I be able to compile Lcnc from source on Bebian running on x64?
- Thank you received: 7488
16 Dec 2022 23:56 #259689
Replied by tommylight on topic Install on 64 bit machine?
Yes, it is for 64 bit PC.
It does not work on a 32 bit PC
Yes, you can compile LinuxCNC on it, although it is already installed.
And yes, you can have the installed (buildbot) version and a Run In Place version on the same PC/installation.
The following user(s) said Thank You: sam2004
- sam2004
17 Dec 2022 00:03 #259690
by sam2004
Replied by sam2004 on topic Install on 64 bit machine?
Thank you.
What would be my options if I have 32 bit computer?
- sam2004
17 Dec 2022 00:05 #259692
by sam2004
About the Debian version on this link www.debian.org/CD/live/ Is it already have Linuxcnc with it?
17 Dec 2022 00:38 - 17 Dec 2022 00:40 #259694
For 32 bit PC use the Wheezy version from here
linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
Edit:
Be aware this version and Debian Wheezy are not supported any more, they are very old.
No this does not have LinuxCNC.About the Debian version on this link www.debian.org/CD/live/ Is it already have Linuxcnc with it?
Edit:
Last edit: 17 Dec 2022 00:40 by tommylight. Reason: more info
Time to create page: 0.095 seconds
