Linux Mint install
- mgm
- Thank you received: 13
28 Dec 2022 01:26 - 01 Jan 2023 12:06 #260451
by mgm
Linux Mint install was created by mgm
I have an Acer Aspirin S7 and have been trying for 2 days to install Linus means but unfortunately without success!
Has anyone done this and if so how?
I'm about to throw the thing out the window !!!
I get it installed but then it does not boot !
Aborts with no boot device ...
Last edit: 01 Jan 2023 12:06 by mgm.
- Thank you received: 7488
28 Dec 2022 02:11 #260452
Replied by tommylight on topic Linux Mint install
-power off
-power on
-press F2 to enter BIOS
-go to boot section
-arrows to first boot device
-enter
-choose the hard drive/ssd/nvme
-exit saving changes.
-power on
-go to boot section
-enter
- mgm
28 Dec 2022 10:26 #260460
by mgm
Replied by mgm on topic Linux Mint install
The boot order is correct!
Currently it tries to restart aborts and restarts againĀ
When I press f12 for boot manager also appear the two hard drives, but it does not matter what I select ......
I suspect it is because of the merging of the two disks from the core. Because my partitions do not start with dev/sda or so but with
dev/mappen/.........../hdd0
- mgm
30 Dec 2022 19:29 #260563
by mgm
So I have now got LM installed.
I have struggled 2 days with sobering but also good results.
The Acer Aspire S7 has a RAID array of 2 hard drives.
But this RAID is not readable or changeable by LINUX!
It took me 2 days to find out ....
This RAID is only resolvable with a WIN reinstallation.
But you have to change the setup mode from RAID to AHCI in the BIOS and switch off the Sekure BIOS.
Afterwards the association is dissolved with the new installation of Win!
After the WIN installation either as dual or as singel LM can be installed ....
Time to create page: 0.095 seconds
