Loading 2.5 offline
24 Oct 2010 11:28 #4818
by Rick G
Loading 2.5 offline was created by Rick G
Hello,
There are several ways to obtain and install EMC2. The simplest seems to be using a Live CD.
This has worked great. However two of my machines (one running 8.04 and EMC2.3 , the other 8.04 and EMC2.4) are now at a shop that does not have an internet connection.
I would like to try 2.5 on these and to be able to update them from time to time. What is the best method to do this?
Rick G
Rick G
24 Oct 2010 12:35 - 24 Oct 2010 12:37 #4819
by BigJohnT
Replied by BigJohnT on topic Re:Loading 2.5 offline
Rick,
You might try copying your dev directory to a USB stick then transfer that to the challenged computers to try a 2.5 RIP.
A tip here .
A tip here .
Last edit: 24 Oct 2010 12:37 by BigJohnT.
24 Oct 2010 13:35 #4820
by Rick G
Replied by Rick G on topic Re:Loading 2.5 offline
John,
I will try today.
Rick
I will try today.
Rick
25 Oct 2010 09:34 #4825
Replied by andypugh on topic Re:Loading 2.5 offline
Ubuntu Lucid includes a utility that can create bootable USB sticks from an ISO CD image.
It is in the System Admin menu I think.
This is the approach I used to get EMC onto my new machine (No CD drive)
25 Oct 2010 10:08 #4830
by Rick G
Andy,
That sounds like an interesting idea however I have had no luck with Lucid and EMC2. The first computer I loaded it on (which is fine with Hardy) failed the latency test terribly. Tried several fixes with no luck and went back to Hardy.
Rick G
Rick G
25 Oct 2010 10:34 #4832
If you have a Lucid machine, you could make a Hardy boot-drive using the Hardy ISO.
I assume that the package can be installed on Hardy too, but I don't know what it is called.
25 Oct 2010 12:27 #4834
by Rick G
Andy,
I do not have a Lucid machine right now, but I could put one together. I am hoping to find the solution to getting EMC2 to run on Lucid for me at some point anyway but there is only so much time... What I really wanted to do was have the stable version of EMC2 and 2.5 on the same machine. So I could try 2.5 and keep 2.3 or 2.4 running.
I did download the files and following the instructions for installing 2.5 i got as far as ..
$ cd src
$ ./autogen.sh
$ ./configure
At which point I receive the error "compiler cannot create executables"
Thanks,
Rick
$ cd src
$ ./autogen.sh
$ ./configure
Thanks,
Rick
25 Oct 2010 18:48 #4852
by BigJohnT
Rick,
Did you install the build dependencies?
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ge_already_installed
25 Oct 2010 20:36 #4857
by Rick G
John,
Good call, I must have jumped over that (maybe it is time for new glasses). I thought that when I went to package manager and downloaded the files for emc dev I would have everything.
Right now when I configure I get...
checking for glib ... configure : error no -- required until somebody makes modbus optional
I will go to the shop and try now.
Thanks,
Rick
Thanks,
Rick
25 Oct 2010 21:22 #4859
by BigJohnT
Hi Rick,
I wish I could take credit but cradek pointed that out when I asked on the IRC.
Time to create page: 0.162 seconds
