Installing LinuxCnc 2.8.0 Booster
- JurisRu
30 Jul 2023 07:31 #276550
by JurisRu
Installing LinuxCnc 2.8.0 Booster was created by JurisRu
Hey guys!
When I install LinuxCNC Wheeze everything goes fine.
When I run LinuxCNC Booster 2.8.0 or 2.8.2 or 2.8.4 as live disc - everything is fine. The network is working, the Internet is working. But when I install these versions - the installation stops at 'network configuration'. Where is the problem?
- Thank you received: 7488
30 Jul 2023 11:26 #276557
Replied by tommylight on topic Installing LinuxCnc 2.8.0 Booster
Use Debian BookWorm 12, it should be pinned at the top.
If you want to use Buster or Wheezy, when installing choose "continue without networking", or similar.
- JurisRu
30 Jul 2023 12:24 #276564
by JurisRu
Replied by JurisRu on topic Installing LinuxCnc 2.8.0 Booster
I had installed Debian 12 - unfortunately LinuxCnc was not there. And in general, the interface there is ugly and inconvenient!
30 Jul 2023 12:53 #276567
To install LinuxCNC on Debian 12 you only need a single line in a terminal
sudo apt update
sudo apt install linuxcnc-uspace
Well, 2 lines
What DE did you try? XFCE? Mate? Gnome? Cinnamon?
Wheezy and Buster use XFCE, it is not good looking but it works.
sudo apt update
Well, 2 lines
- JurisRu
30 Jul 2023 13:03 #276568
by JurisRu
I have a Dell Optiplex 760. www.itechguides.com/product-specs/dell-optiplex-760-specs/
It supports 64 bit system. What would you recommend - XFCE? Mate? Gnome? Cinnamon?
30 Jul 2023 13:10 #276569
<4GB of RAM = XFCE
>4GB of RAM = Mate
>8GB with good graphic card = GNOME or Cinnamon
>4GB of RAM = Mate
The following user(s) said Thank You: JurisRu
- JurisRu
30 Jul 2023 13:17 #276570
by JurisRu
Great thanks!
Time to create page: 0.296 seconds
