upgrade to hardy 8.04 and emc2 2.3.1 not working
09 Jul 2009 01:32 #497 by steve10778
Hello to all!
This is my first post, I am having a problem with my mill. I upgraded from to the latest version of emc2, using axis gui on a 3 axis bridgeport. i upgraded by reformatting the computer using the live cd and installing from scratch. I did save my old configs folder so i have all my tuning parameters when i get to that. My reason for upgrading was to take advantage of the improvements in axis, mainly the bugfixes and the ability to restart at a selected line of code.
so here is my problem, using ppmc board set, 3 axis cnc on bridgeport mill, upon trying to open emc, i get the emc2 error print file window, i ge the debug info as follows:
Hal: Error: pin' axis.3.motor-pos-fb' not found
ppmc_servo.hal:20 link failed
5242
pid tty stat time command
stop realtime threads
unloading hal components
and dmesg., as follows: WHAT DO I DO NOW? I GREATLY APPRECIATE ANY HELP I CAN GET, AND I WOULD LIKE TO PUBLICLY THANK JON ELSON FOR HIS WELL MADE PPMC BOARDS, THEY WORK GREAT AND HE HAS HELPED ME OUT OVER THE LAST COUPLE BUMPS I HAD TO "MILL DOWN", eh eh eh
thanks
steve in ohio, This email address is being protected from spambots. You need JavaScript enabled to view it.,
steve@cncmill:~$ dmesg
[ 0.000000] Linux version 2.6.24-16-rtai (root@hardy) (gcc version 4.2.3 (Ubuntu 4.2.3-2ubuntu7)) #1 Tue Sep 30 22:54:33 EEST 2008 (Ubuntu 2.6.24-12.22-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000000fe77000 (usable)
[ 0.000000] BIOS-e820: 000000000fe77000 - 000000000fe79000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000000fe79000 - 0000000010000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 254MB LOWMEM available.
[ 0.000000] Entering add_active_range(0, 0, 65143) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 65143
[ 0.000000] HighMem 65143 -> 65143
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 65143
[ 0.000000] On node 0 totalpages: 65143
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 476 pages used for memmap
[ 0.000000] Normal zone: 60571 pages, LIFO batch:15
[ 0.000000] HighMem zone: 0 pages used for memmap
[ 0.000000] Movable zone: 0 pages used for memmap
[ 0.000000] DMI 2.3 present.
[ 0.000000] Allocating PCI resources starting at 20000000 (gap: 10000000:eec00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64635
[ 0.000000] Kernel command line: root=UUID=b2fde558-620d-4af9-9f09-3a686128c49a ro quiet splash
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] Detected 1196.374 MHz processor.
[ 11.569931] I-pipe 2.0-04: pipeline enabled.
[ 11.571900] Console: colour VGA+ 80x25
[ 11.571911] console [tty0] enabled
[ 11.572544] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 11.573084] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 11.597408] Memory: 248176k/260572k available (1440k kernel code, 11820k reserved, 573k data, 228k init, 0k highmem)
[ 11.597427] virtual kernel memory layout:
[ 11.597429] fixmap : 0xfffed000 - 0xfffff000 ( 72 kB)
[ 11.597432] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 11.597434] vmalloc : 0xd0800000 - 0xff7fe000 ( 751 MB)
[ 11.597437] lowmem : 0xc0000000 - 0xcfe77000 ( 254 MB)
[ 11.597439] .init : 0xc02fa000 - 0xc0333000 ( 228 kB)
[ 11.597441] .data : 0xc026836d - 0xc02f77ec ( 573 kB)
[ 11.597444] .text : 0xc0100000 - 0xc026836d (1440 kB)
[ 11.597450] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 11.597525] SLUB: Genslabs=11, HWalign=32, Order=0-1, MinObjects=4, CPUs=1, Nodes=1
[ 11.677466] Calibrating delay using timer specific routine.. 2393.87 BogoMIPS (lpj=4787746)
[ 11.677517] Security Framework initialized
[ 11.677528] SELinux: Disabled at boot.
[ 11.677552] AppArmor: AppArmor initialized
[ 11.677561] Failure registering capabilities with primary security module.
[ 11.677573] Mount-cache hash table entries: 512
[ 11.677773] CPU: After generic identify, caps: 0383fbff 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 11.677792] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 11.677796] CPU: L2 cache: 256K
[ 11.677800] CPU: After all inits, caps: 0383fbff 00000000 00000000 00000040 00000000 00000000 00000000 00000000
[ 11.677816] Compat vDSO mapped to ffffe000.
[ 11.677835] CPU: Intel(R) Celeron(TM) CPU 1200MHz stepping 04
[ 11.677845] Checking 'hlt' instruction... OK.
[ 11.693751] Freeing SMP alternatives: 0k freed
[ 11.694133] net_namespace: 64 bytes
[ 11.695131] NET: Registered protocol family 16
[ 11.695545] EISA bus registered
[ 11.721231] PCI: PCI BIOS revision 2.10 entry at 0xfbe8e, last bus=1
[ 11.721237] PCI: Using configuration type 1
[ 11.721240] Setting up standard PCI resources
[ 11.724099] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 11.724589] PCI: Probing PCI hardware
[ 11.724625] PCI: Probing PCI hardware (bus 00)
[ 11.724900] PCI quirk: region 0800-087f claimed by ICH4 ACPI/GPIO/TCO
[ 11.724907] PCI quirk: region 0880-08bf claimed by ICH4 GPIO
[ 11.725292] PCI: Transparent bridge - 0000:00:1e.0
[ 11.737587] AppArmor: AppArmor Filesystem Enabled
[ 11.738323] PCI: Bridge: 0000:00:1e.0
[ 11.738330] IO window: e000-efff
[ 11.738340] MEM window: ff900000-ffafffff
[ 11.738346] PREFETCH window: disabled.
[ 11.738367] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 11.738393] NET: Registered protocol family 2
[ 11.741411] Time: tsc clocksource has been installed.
[ 11.773508] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 11.773926] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 11.774137] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 11.774237] TCP: Hash tables configured (established 8192 bind 8192)
[ 11.774242] TCP reno registered
[ 11.785692] checking if image is initramfs... it is
[ 13.078852] Freeing initrd memory: 6859k freed
[ 13.080014] audit: initializing netlink socket (disabled)
[ 13.080100] audit(1247098851.488:1): initialized
[ 13.084280] VFS: Disk quotas dquot_6.5.1
[ 13.084346] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 13.084704] io scheduler noop registered
[ 13.084711] io scheduler anticipatory registered
[ 13.084714] io scheduler deadline registered
[ 13.084744] io scheduler cfq registered (default)
[ 13.084776] Boot video device is 0000:00:01.0
[ 13.085306] isapnp: Scanning for PnP cards...
[ 13.438724] isapnp: No Plug & Play device found
[ 13.506920] Real Time Clock Driver v1.12ac
[ 13.506931] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 13.507091] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 13.507402] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 13.509519] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 13.509686] input: Macintosh mouse button emulation as /devices/virtual/input/input0
[ 13.509948] PNP: No PS/2 controller found. Probing ports directly.
[ 13.511888] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 13.511898] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 13.519762] mice: PS/2 mouse device common for all mice
[ 13.519987] EISA: Probing bus 0 at eisa.0
[ 13.520032] EISA: Detected 0 cards.
[ 13.520245] NET: Registered protocol family 1
[ 13.520274] Using IPI Shortcut mode
[ 13.520466] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 13.520470] EDD information not available.
[ 13.521215] Freeing unused kernel memory: 228k freed
[ 13.555622] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input1
[ 14.994666] fuse init (API version 7.9)
[ 15.586787] 3c59x: Donald Becker and others.
[ 15.586805] 0000:01:0c.0: 3Com PCI 3c905C Tornado at d0816c00.
[ 15.608143] usbcore: registered new interface driver usbfs
[ 15.608193] usbcore: registered new interface driver hub
[ 15.608626] SCSI subsystem initialized
[ 15.645564] usbcore: registered new device driver usb
[ 15.717712] USB Universal Host Controller Interface driver v3.0
[ 15.717881] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 15.717889] uhci_hcd 0000:00:1f.2: UHCI Host Controller
[ 15.718367] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[ 15.718416] uhci_hcd 0000:00:1f.2: irq 11, io base 0x0000ff80
[ 15.718701] usb usb1: configuration #1 chosen from 1 choice
[ 15.718751] hub 1-0:1.0: USB hub found
[ 15.718764] hub 1-0:1.0: 2 ports detected
[ 15.731925] libata version 3.00 loaded.
[ 15.827843] ata_piix 0000:00:1f.1: version 2.12
[ 15.827970] PCI: Setting latency timer of device 0000:00:1f.1 to 64
[ 15.831570] scsi0 : ata_piix
[ 15.833548] scsi1 : ata_piix
[ 15.833671] ata1: PATA max UDMA/66 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 15.833677] ata2: PATA max UDMA/66 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 15.998422] ata1.00: ATA-5: WDC WD200EB-75CPF0, 06.04G06, max UDMA/100
[ 15.998431] ata1.00: 39102336 sectors, multi 8: LBA
[ 16.014387] ata1.00: configured for UDMA/66
[ 16.061088] usb 1-2: new full speed USB device using uhci_hcd and address 2
[ 16.230088] usb 1-2: configuration #1 chosen from 1 choice
[ 16.235052] hub 1-2:1.0: USB hub found
[ 16.235888] hub 1-2:1.0: 3 ports detected
[ 16.281175] ata2.01: failed to IDENTIFY (I/O error, err_mask=0x1)
[ 16.281189] ata2: failed to recover some devices, retrying in 5 secs
[ 21.711510] ata2.00: ATAPI: SAMSUNG CD-ROM SN-124, N102, max UDMA/33
[ 21.883278] ata2.00: configured for UDMA/33
[ 21.883572] scsi 0:0:0:0: Direct-Access ATA WDC WD200EB-75CP 06.0 PQ: 0 ANSI: 5
[ 21.884798] scsi 1:0:0:0: CD-ROM SAMSUNG CD-ROM SN-124 N102 PQ: 0 ANSI: 5
[ 21.907947] Driver 'sd' needs updating - please use bus_type methods
[ 21.915192] sd 0:0:0:0: [sda] 39102336 512-byte hardware sectors (20020 MB)
[ 21.915229] sd 0:0:0:0: [sda] Write Protect is off
[ 21.915235] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 21.915272] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 21.915414] sd 0:0:0:0: [sda] 39102336 512-byte hardware sectors (20020 MB)
[ 21.915435] sd 0:0:0:0: [sda] Write Protect is off
[ 21.915440] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 21.915474] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 21.915481] sda:<4>Driver 'sr' needs updating - please use bus_type methods
[ 21.956463] sda1 sda2 < sda5 >
[ 21.984095] sd 0:0:0:0: [sda] Attached SCSI disk
[ 21.999245] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 21.999290] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 22.004067] sr0: scsi3-mmc drive: 24x/24x cd/rw xa/form2 cdda tray
[ 22.004080] Uniform CD-ROM driver Revision: 3.20
[ 22.004224] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 22.508525] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 22.508535] EXT3-fs: write access will be enabled during recovery.
[ 22.945353] kjournald starting. Commit interval 5 seconds
[ 22.945400] EXT3-fs: sda1: orphan cleanup on readonly fs
[ 22.945415] ext3_orphan_cleanup: deleting unreferenced inode 1084127
[ 22.945471] EXT3-fs: sda1: 1 orphan inode deleted
[ 22.945476] EXT3-fs: recovery complete.
[ 22.947868] EXT3-fs: mounted filesystem with ordered data mode.
[ 32.426659] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 32.567482] iTCO_vendor_support: vendor-support=0
[ 32.570227] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.02 (26-Jul-2007)
[ 32.570342] iTCO_wdt: failed to reset NO_REBOOT flag, reboot disabled by hardware
[ 32.570355] iTCO_wdt: No card detected
[ 32.602508] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 32.630155] Linux agpgart interface v0.102
[ 32.724274] agpgart: Detected an Intel i810 Chipset.
[ 32.737012] agpgart: AGP aperture is 64M @ 0xf8000000
[ 32.787291] intel_rng: FWH not detected
[ 32.958416] i810_smbus 0000:00:01.0: i810/i815 i2c device found.
[ 33.226456] logips2pp: Detected unknown logitech mouse model 127
[ 33.696351] input: ImExPS/2 Logitech Explorer Mouse as /devices/platform/i8042/serio1/input/input3
[ 34.023609] PCI: Setting latency timer of device 0000:00:1f.5 to 64
[ 34.641985] intel8x0_measure_ac97_clock: measured 56001 usecs
[ 34.641995] intel8x0: clocking to 41143
[ 36.881624] lp: driver loaded but no devices found
[ 37.103208] Adding 746980k swap on /dev/sda5. Priority:-1 extents:1 across:746980k
[ 37.681524] EXT3 FS on sda1, internal journal
[ 39.389876] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 41.801272] ppdev: user-space parallel port driver
[ 42.038188] audit(1247098881.421:2): type=1503 operation="inode_permission" requested_mask="a::" denied_mask="a::" name="/dev/tty" pid=4155 profile="/usr/sbin/cupsd" namespace="default"
[ 43.468130] eth0: setting half-duplex.
[ 43.576587] Bluetooth: Core ver 2.11
[ 43.586245] NET: Registered protocol family 31
[ 43.586255] Bluetooth: HCI device and connection manager initialized
[ 43.586263] Bluetooth: HCI socket layer initialized
[ 43.680810] Bluetooth: L2CAP ver 2.9
[ 43.680821] Bluetooth: L2CAP socket layer initialized
[ 43.751435] Bluetooth: RFCOMM socket layer initialized
[ 43.751485] Bluetooth: RFCOMM TTY layer initialized
[ 43.751489] Bluetooth: RFCOMM ver 1.8
[ 46.844655] [drm] Initialized drm 1.1.0 20060810
[ 46.870799] PCI: Setting latency timer of device 0000:00:01.0 to 64
[ 46.871270] [drm] Initialized i810 1.4.0 20030605 on minor 0
[ 46.872130] mtrr: base(0xf8000000) is not aligned on a size(0x180000) boundary
[ 46.884631] [drm] Using v1.4 init.
[ 50.098011] [drm:drm_release] *ERROR* reclaim_buffers_locked() deadlock. Please rework this
[ 50.098018] driver to use reclaim_buffers_idlelocked() instead.
[ 50.098021] I will go on reclaiming the buffers anyway.
[ 98.135362] NET: Registered protocol family 10
[ 98.137629] lo: Disabled Privacy Extensions
[ 98.139017] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 145.201493] I-pipe: Domain RTAI registered.
[ 145.201519] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 145.201524] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 145.201534] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 145.201538] PIPELINE layers:
[ 145.201542] d0db1000 9ac15d93 RTAI 200
[ 145.201546] c0383180 0 Linux 100
[ 145.308651] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 145.310925] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 145.310940] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 145.310948] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 1196374000 hz.
[ 145.310953] RTAI[sched]: timer setup = 2010 ns, resched latency = 2688 ns.
[ 145.473355] RTAI[math]: loaded.
[ 145.527511] rtapi: no version for "nano2count" found: kernel tainted.
[ 146.796663] PPMC: shutting down
[ 147.040809] RTAI[math]: unloaded.
[ 147.125272] SCHED releases registered named ALIEN RTGLBH
[ 147.146882] RTAI[malloc]: unloaded.
[ 147.245098] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 147.251896] I-pipe: Domain RTAI unregistered.
[ 147.251913] RTAI[hal]: unmounted.
[ 774.102270] I-pipe: Domain RTAI registered.
[ 774.102295] RTAI[hal]: <3.6.1> mounted over IPIPE-NOTHREADS 2.0-04.
[ 774.102300] RTAI[hal]: compiled with gcc version 4.2.4 (Ubuntu 4.2.4-1ubuntu3).
[ 774.102310] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 774.102314] PIPELINE layers:
[ 774.102318] d0db1000 9ac15d93 RTAI 200
[ 774.102322] c0383180 0 Linux 100
[ 774.137462] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 774.138455] RTAI[sched]: loaded (IMMEDIATE, UP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 774.138469] RTAI[sched]: hard timer type/freq = 8254-PIT/1193180(Hz); default timing: periodic; linear timed lists.
[ 774.138476] RTAI[sched]: Linux timer freq = 250 (Hz), CPU freq = 1196374000 hz.
[ 774.138481] RTAI[sched]: timer setup = 2010 ns, resched latency = 2688 ns.
[ 774.268679] RTAI[math]: loaded.
[ 775.115308] PPMC: shutting down
[ 775.297424] RTAI[math]: unloaded.
[ 775.395110] SCHED releases registered named ALIEN RTGLBH
[ 775.416384] RTAI[malloc]: unloaded.
[ 775.514732] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 775.521240] I-pipe: Domain RTAI unregistered.
[ 775.521258] RTAI[hal]: unmounted.
steve@cncmill:~$
09 Jul 2009 10:23 #500 by steve10778
Update, 7/9/2009;
I changed my .ini axes section from 3 axis back to four and was able to get axis gui to come up., i will have to shake it down after work today and see if all is well. There appears to be a problem when i disable the 4th axis. with my old version, you could change it from 4 to 3 without issue?
Also, for the new comers to emc, make sure your parrallel port is set to epp mode, this is done on your computer, use the f2 or f12 what have you when you restart your computer to enter the setup menus, find this and change it. that caused me some problems earlier.
09 Jul 2009 11:55 #501 by BigJohnT
If you have things in your hal file that are looking for the 4th axis then it will not load until you remove them. Usually the pop up window tells you what is missing. In the middle somewhere.
You might look for a line like this one in your hal file.
setp stepgen.3.position-scale [AXIS_3]SCALE
then make sure you remove all the items for the 4th axis.
09 Jul 2009 12:51 #504 by steve10778
thanks john, im thinking something like that also, i will post back my status tonight after i re parameterize some things. i have to update all of my ini files and i/o so the axes function properly and the limits are monitored..
thanks
steve
10 Jul 2009 10:48 #507 by steve10778
I decided not to delete anything and just re enabled the 4th axis, set all homing vel to zero. It doesnt bother me much to have the A axis displayed for now. I have other problems though.
I have all three servo axis running now, and they home properly. I described a homing sequence in .ini. axis doesnt allow 'home all' for some reason so i need to get a more thorough look at that.
I can run the emc2 axis logo program without issue. However if i try to run 3d chips (from example files) or others, i get no movement at all., and it really drags the computer down, it gets sticky, takes forever to abort, mouse movements are slow, etc etc. I think im having problems with hal_manual_toolchange, . If i run axis.sim these programs run fine so i am going to print out all the sim configs and take them out to the shop and compare them to my data and see if i have fouled something up.
I also want to put in HOME_FINAL_VEL, I put it in the .ini files under each axis with a setpoint but it is still moving fast after it picks up the marker pulse.
145.527511] rtapi: no version for "nano2count" found: kernel tainted. <<<< What does this mean, looks bad to me?
so im still jammed up over here, ill post with my findings. if anybody sees any obvious things let me know.
10 Jul 2009 11:47 #508 by BigJohnT
Did you use the Stepconf Wizard to create you configuration files? If you did then just run it again and remove the pins for the A axis and it will take care of the rest.
Home All only works when you have all of the axis home sequences in the ini file. Since you don't have a 4th axis this would not work until you remove the 4th axis or set that axis to -1.
What did you set home final vel to? it is in units per second...
www.linuxcnc.org/docview/html//config_in...b:%5BAXIS%5D-section
10 Jul 2009 12:58 #509 by steve10778
i didnt use stepconf, i have servos, so i set all of my parameters manually a while back, i edited the files manually when i upgraded. I think home sequence i messed up, reading the manual the first sequence is 0, i think i started with one. I have to check that and fix it tonight when i get home from work. I will get some notes and post actual problems with the proper nomenclature later on. thanks for your help john. im also going to copy the axis manual toolchange lines as they are in the sim file, putting them in the same place on my .ini. I think i set the home final vel to the same as home latch vel, i would like it to not go to rapid speed on final approach to the home offset position.
10 Jul 2009 15:13 #510 by BigJohnT
I prefer a less than rapid speed to home as well.
In the Trunk version there is a servo wizard called pcconf. As I recall it is for Mesa 5i20 card but I have not looked at it in a month or two. Dunno if that helps or not.
10 Jul 2009 21:35 - 12 Jul 2009 12:07 #512 by steve10778
hello to all, here is my status as of now,,
1. i set my home sequence as follows, axis-0, 0 axis1,1 axis-2, 1 axis-3, 1., but i still dont get the home all option.
2. Home_final_vel, this doesnt seem to work either. i set this to .5 for axis 1 and 2, z axis doesnt get moved for home, home is where ever same with a axis.
3. most important, i am having major issues when i try to run a program. first lets start with what does work, i can home all axis, jog, mdi etc. computer mouse response is fast. i can run the axis logo program fine. (there are no tool changes, remember this because i think its related) .
now i can run all example programs and get prompted for tool changes when i run axis.sim.
on my machine, when i try to run chips3d.ngc, i get no motion, no prompt for tool changes, and the computer gets glitchy and slow. if i hit stop, and go to mdi, i can type in machine movements and nothing happens. emc status shows it is at t1m6. i can however jog and rehome the axis, but no programs will run after this happens. below please find my dmesg results. can the developers or someone look at this and see if my install is messed up? i also made the mistake of saying 2.3.1, but i believe it is 2.3.2. i am going to go and try to comment out # anything that is for the 4th axis, because i am not using it and see if that has any effect. i think my problem may be in my ini file , what do i need to have in my ini for hal manual toolchange, and also in the hal load file, i am using the ppmc axis , on a 3 axis bridgeport. if you need any other info to investigate this problem please ask. my personal email is This email address is being protected from spambots. You need JavaScript enabled to view it. also. i can also give my phone number out if anyone cares to talk in person. I would really like to get my machine back up and running., i new i was taking a risk when i updated, but i didnt think it could be so hard ooops.
Last edit: 12 Jul 2009 12:07 by BigJohnT. Reason: remove dmesg part at Steves request
11 Jul 2009 01:29 - 12 Jul 2009 12:08 #513 by steve10778
reposted,,,,, trying to reformat the whole mess and start over. if that doesnt work i may try putting 6.06 back on and then updating emc? i dont know how this got so far off. let me know if you guys have any ideas...
thank you!
steve
Last edit: 12 Jul 2009 12:08 by BigJohnT. Reason: remove dmesg part at Steves request
Time to create page: 0.180 seconds
