D510mo system
30 Oct 2010 22:09 #4972
by Bob
D510mo system was created by Bob
Thought it would be good to start a new thread on this motherboard. I am happy to report that I have this system fully functional. The latency test show very good numbers. The latency test does seem to be somewhat variable. If you reset it and wait a few minutes, the numbers can vary quite a bit but they are all good. I have the computer mounted on the back of a monitor. I used a mini -ITX case with no fan. I am running a Sherline mill with steppers. I am using 1/8 micro stepping and everything came up and seems to be working fine without even any tuning of parameters. All in all very pleased with the cleanliness of this whole setup !!:
31 Oct 2010 13:12 #4979
by BigJohnT
Replied by BigJohnT on topic Re:D510mo system
Cool, do you have any photos of the setup?
31 Oct 2010 13:45 #4982
by Bob
Replied by Bob on topic Re:D510mo system
I cand send some -- any guidlines on file size, number of pics?
31 Oct 2010 14:04 #4983
by BigJohnT
You can attach one image to each message and when you hover over the Browse... button it tells you the limits in the line above the message area.
- TarHeelTom
29 Oct 2011 06:48 #14362
by TarHeelTom
Replied by TarHeelTom on topic Re:D510mo system
Wish I'd discovered the mini -ITX case sooner. Looks like exactly what the doctor ordered for the cabinet on my Bridgeport.
Anyone know the secret handshake for increasing the screen sleep time on this motherboard?
Every time I get a program running and get engrossed in it, I look up and the screen is in sleep mode, and I have to enter the password to get access again. Thank goodness this only affect the video, and not the motions.
Tom
Tom
29 Oct 2011 11:01 #14367
by Rick G
Replied by Rick G on topic Re:D510mo system
Have you tried...
System
Preferences
Screen saver
Look at the check box for activate screen saver....
Also
Look at the power management section there.
Rick G
System
Preferences
Screen saver
Also
Rick G
- TarHeelTom
29 Oct 2011 13:33 #14378
by TarHeelTom
Rick G wrote:
No, haven't tried that. Seems like when I have that particular computer running I'm always pressed for time, and the ergonomics surrounding it aren't good for just browsing around.
But I'll try it in a few minutes.
Tom
Have you tried...
System
Preferences
Screen saver
Also
Rick G
Tom
