Linuxcnc Debian bookworm update from 2.9 to 2.10
  • aabtech
  • aabtech's Avatar Topic Author
  • Premium Member
  • Premium Member
09 Aug 2023 12:01 #277450 by aabtech
Hi, I have successfully install linuxcnc on Debian bookworm working correctly but am finding it defecult to update it to Linuxcnc 2.10.
09 Aug 2023 14:07 #277456 by rodw
If you have followed the getting linuxcnc docs at linuxcnc.org/docs/2.9/html/getting-start...etting-linuxcnc.html
you just need to edit /etc/apt/sources.list.d/linuxcnc.list and replace 2.9-uspace with master-uspace
then this should work
sudo apt update
sudo apt upgrade
If this fails  remove the packages
sudo apt remove linuxcnc-uspace linuxcnc-uspace-dev
and reinstall
sudo apt install linuxcnc-uspace linuxcnc-uspace-dev
09 Aug 2023 14:09 #277457 by rodw
  • aabtech
  • Premium Member
  • Premium Member
09 Aug 2023 23:45 #277503 by aabtech
  • Platinum Member
  • Platinum Member
10 Aug 2023 01:39 #277508 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Linuxcnc Debian bookworm update from 2.9 to 2.10
Did you follow the instructions Rod linked to.
It looks like you haven't made the changes and\or done sudo apt-get update. It also looks like you haven't quite followed the instructions as laid out.
As apt is wanting to install 2.9 rather than 2.10
14 Nov 2023 04:09 - 14 Nov 2023 04:10 #285356 by frayja2002
Replied by frayja2002 on topic Linuxcnc Debian bookworm update from 2.9 to 2.10
Sorry to restart an old thread but I'm still a little confused by the instructions.
I have entered the following lines in my sources file...
deb buildbot.linuxcnc.org/ bookworm main non-free-firmware
deb-src buildbot.linuxcnc.org/ bookworm main non-free-firmware
but its is still telling me it cannot find the repository.
I'm guessing the end part needs to be changed but I'm not sure what to put in there.
If you could give an example I would appreciate it.
Alex
Last edit: 14 Nov 2023 04:10 by frayja2002.
14 Nov 2023 05:12 #285362 by tommylight
Replied by tommylight on topic Linuxcnc Debian bookworm update from 2.9 to 2.10
Those do not look like official LinuxCNC repositories, where did you get those?
14 Nov 2023 06:00 #285368 by rodw
Looks like you are still using the old Buster ISO which won't work well with 2.10.
There isn't an easy way I'm sorry
I recommend you install the latest Debian Bookworm ISO which I just updated.
drive.google.com/file/d/16o5cbMDE48tZ0tK.../view?usp=drive_link
You will need to update /etc/apt/sources.list.d/linuxcnc-uspace.list with the values here
buildbot2.highlab.com/
Also edit /etc/apt/preferences.d/99linuxcnc-uspace.pref with the values from th ebuildbot above
Alternatively, grab the latest 2.10 debs from the buildbot above and install with dpkg -i (but having it all automated  makes it super easy to keep current)
22 Feb 2024 12:45 - 22 Feb 2024 12:51 #294010 by RobotMatic
Replied by RobotMatic on topic Linuxcnc Debian bookworm update from 2.9 to 2.10
I am trying to install linuxcnc 2.10
When I try to update it tells me that the repository is not signed. what am I doing wrong?
i am using Debian bookworm 12.4-  I have removed linuxcnc 2.9.2
deb buildbot2.highlab.com/debian/ bookworm master-uspace 2.10-uspace scratch-uspace
deb-src  buildbot2.highlab.com/debian/ bookworm master-uspace 2.10-uspace scratch-uspace
package: linuxcnc-uspace
pin: release o=https://www.linuxcnc.org/ bookworm base master-uspace
Pin-Priority: 500
package: linuxcnc-uspace-dev
Pin-Priority: 500
package: linuxcnc-uspace-doc-en
Pin-Priority: 500
package: linuxcnc-uspace-doc-es
Pin-Priority: 500
thank
Last edit: 22 Feb 2024 12:51 by RobotMatic.
22 Feb 2024 17:08 #294029 by rodw
The getting Linuxcnc docs in 2.9 tell you how to install using a script (section 7.3 from memory)
Do this to set the apt security keys up then edit the files as you are doing. I think it will work
The following user(s) said Thank You: RobotMatic
Time to create page: 0.207 seconds
