Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
20 Jun 2024 23:21 #303453 by cakeslob
elovalvo, where can I find youre raspian12 bookworm image for the rpi4? is it the same as rpi5? I went searching through a bunch of threads but cannot find RPi4
21 Jun 2024 15:19 #303495 by elovalvo
No, the images are different.
If you wait a couple of days I can create updated ones for both versions of Raspberry
The following user(s) said Thank You: cakeslob
24 Jun 2024 14:40 - 25 Jun 2024 06:39 #303696 by elovalvo
Here are the files I promised you
drive.google.com/file/d/1jBEO7Acl0C0t4id.../view?usp=drive_link  (Pi5 - kernel-6.6.32-v8-16k-elv.zip)
drive.google.com/file/d/1B58q4xJgBR4GnxI.../view?usp=drive_link  (Pi4, Pi400 - kernel-6.6.32-v8-elv.zip)
drive.google.com/file/d/1ltrkbEiI_BssNY0.../view?usp=drive_link (install-kernel)
Since for building the RT kernel I followed this procedure (forums.raspberrypi.com/viewtopic.php?t=343387), in the next post I describe the procedures for using.
Last edit: 25 Jun 2024 06:39 by elovalvo.
24 Jun 2024 15:01 - 24 Jun 2024 15:07 #303697 by elovalvo
To install raspian12 bookworm image, prepare an SD card with the RaspiOS version for the type of Raspberry you are interested in (pi4, Pi400, Pi5).
I find it comfortable
www.raspberrypi.com/software/
because it also allows you to select various options (ssh, wifi, locales, etc..).
Boot the SD and run these commands from the terminal to update the RaspiOS version
sudo apt-get update
sudo apt-get upgrade
sudo reboot
Upon reboot, copy the install-kernel files and the zip file to the /tmp directory
Then run these commands from terminal
cd /tmp
chmod +x ./install-kernel
sudo ./install-kernel ./kernel-6.6.32-v8-elv.zip
(in the case of Pi4 and PI400)
or
sudo ./install-kernel ./kernel-6.6.32-v8-16k-elv.zip
(in the case of Pi5)
So you need to edit the cmdline.txt with
sudo nano "/boot/firmware/cmdline.txt"
adding the following commands to the end of the line
isolcpus=2,3 rcu_nocbs=2,3 nohz_full=2,3 max.processor.cstate=1
Last edit: 24 Jun 2024 15:07 by elovalvo.
The following user(s) said Thank You: cakeslob, Cant do this anymore bye all
24 Jun 2024 23:10 #303721 by cakeslob
alright, awesome thank you!
question, your previous images had the rt already installed, is there some limitation to why they arent this time, or is it so you can hit update before loading the kernel?
25 Jun 2024 14:37 #303752 by elovalvo
I chose this procedure because it allows you to choose the best Raspbian configuration (user, password, ssh, wifi, locales, etc..), to update an already existing version, to install the version of LinuxCNC of your choice and other alternatives.
However, for those who don't want to, in these links there are the ready-to-user images with LinuxCNC 2.9.2
(user:pi  pwd:raspberry)
OS: Linux raspberrypi 6.6.32-rpi999-rpi-v8 #1 SMP PREEMPT_RT Mon Jun 24 15:56:31 CEST 2024 aarch64
( image_lcnc_pi4.zip )
OS: Linux raspberrypi 6.6.32-rpi999-rpi-2712 #2 SMP PREEMPT_RT Sun Jun  9 10:10:54 CEST 2024 aarch64
( image_lcnc_pi5.zip )
The following user(s) said Thank You: cakeslob, rdtsc
  • Platinum Member
  • Platinum Member
25 Jun 2024 16:35 #303761 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Another note if you want\need to run Axis you’ll want to use raspi-config to change from wayland to x11. Or anything that depends on the X11 libs, I found the way land compatibility layer really really slow.
The following user(s) said Thank You: elovalvo, cakeslob, rdtsc
  • Platinum Member
  • Platinum Member
04 Jul 2024 09:34 #304364 by Cant do this anymore bye all
Awesome used all of elovalo bits to setup an Rpi5 with Pineberry NVME hat, works great.
The following user(s) said Thank You: tommylight, elovalvo
05 Jul 2024 23:48 #304505 by COFHAL
I have the official version of Debian 12 installed on my PI4, and I use it with my Mesa 7c81, the only problem is that for some reason the SPI port is disabled from the kernel and therefore it is not possible to write a new firmware to that card . Is there a Debian 12 kernel used on the PI4 that has the SPI port enabled by default? . As the official version of the LCN page does not depend on RASPBIAN, it is not possible to enable it with raspi-config or by modifying the config file.
  • Platinum Member
  • Platinum Member
06 Jul 2024 00:58 #304510 by Cant do this anymore bye all
The Linuxcnx version uses the raspbian kernel sources, so it is possible to enable the SPI interface on the RP4. The config.txt file is not in the same location as on a raspbian install, it's still under a sub directory of boot.
The raspbian kernel is patched to allow loading of overlays, the mainline is not.
Modify your config.txt file, reboot and look under the /dev folder for spidev.xx files and they will be there.
I've used rod images and made my own images using the same tools,for testing a diy mesa 7c81 and know that it does work.
We made sure that SPI did work, at least on the RPi4, the RPi5 is a different kettle of fish.
The following user(s) said Thank You: COFHAL
Time to create page: 1.042 seconds
