Debug file information:
inifile: warning: File contains DOS-style line endings.
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: No such device
./Boss5_servo.hal:10: exit value: 1
./Boss5_servo.hal:10: insmod for hm2_pci failed, returned -1
See the output of 'dmesg' for more information.
4979
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
What does
lspci
report?
00:00.0 Host bridge: Intel Corporation Device 5af0 (rev 0b)
Subsystem: ASRock Incorporation Device 5af0
Flags: bus master, fast devsel, latency 0
00:02.0 VGA compatible controller: Intel Corporation Device 5a85 (rev 0b) (prog-if 00 [VGA controller])
Subsystem: ASRock Incorporation Device 5a85
Flags: bus master, fast devsel, latency 0, IRQ 10
Memory at 90000000 (64-bit, non-prefetchable) [size=16M]
Memory at 80000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
00:0e.0 Audio device: Intel Corporation Device 5a98 (rev 0b)
Subsystem: ASRock Incorporation Device d887
Flags: bus master, fast devsel, latency 0, IRQ 25
Memory at 91210000 (64-bit, non-prefetchable) [size=16K]
Memory at 91000000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
00:0f.0 Communication controller: Intel Corporation Device 5a9a (rev 0b)
Subsystem: ASRock Incorporation Device 5a9a
Flags: bus master, fast devsel, latency 0, IRQ 7
Memory at 9121b000 (64-bit, non-prefetchable) [size=4K]
00:12.0 SATA controller: Intel Corporation Device 5ae3 (rev 0b) (prog-if 01 [AHCI 1.0])
Subsystem: ASRock Incorporation Device 5ae3
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
Memory at 91214000 (32-bit, non-prefetchable) [size=8K]
Memory at 91218000 (32-bit, non-prefetchable)
I/O ports at f090
I/O ports at f080
I/O ports at f060
Memory at 91217000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:13.0 PCI bridge: Intel Corporation Device 5ad8 (rev fb) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Kernel driver in use: pcieport
00:13.2 PCI bridge: Intel Corporation Device 5ada (rev fb) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: 91100000-911fffff
00:15.0 USB controller: Intel Corporation Device 5aa8 (rev 0b) (prog-if 30 [XHCI])
Subsystem: ASRock Incorporation Device 5aa8
Flags: bus master, medium devsel, latency 0, IRQ 17
Memory at 91200000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:1f.0 ISA bridge: Intel Corporation Device 5ae8 (rev 0b)
Subsystem: ASRock Incorporation Device 5ae8
00:1f.1 SMBus: Intel Corporation Device 5ad4 (rev 0b)
Subsystem: ASRock Incorporation Device 5ad4
Flags: medium devsel, IRQ 255
Memory at 91216000 (64-bit, non-prefetchable)
I/O ports at f040
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller (rev 11)
Subsystem: ASRock Incorporation Motherboard (one of many)
Flags: bus master, fast devsel, latency 0, IRQ 20
I/O ports at e000
Memory at 91104000 (64-bit, non-prefetchable) [size=4K]
Memory at 91100000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
OK not found at all.
After power on, are there any LEDs lit on the 5I25 card?
