Error during install RTAI Kernel on Debian 12
24 Jan 2024 09:18 - 24 Jan 2024 09:22 #291524 by Seger
I am attempting to install the RTAI kernel on a fresh installation of Debian Bookworm, following the instructions provided in the LinuxCNC Documentation 2.9.Here are the steps I have taken:
  1. Executed the script ( www.linuxcnc.org/linuxcnc-install.sh)
  2. Ran the following commands :
    1. -> sudo apt-get update
    2. -> sudo apt-get install linuxcnc
​​​​​​​However, I encountered an error during the installation process:
dpkg: error processing archive /var/cache/apt/archives/linuxcnc_1%3a2.9.2_amd64.deb (--unpack): trying to overwrite '/usr/share/applications/linuxcnc-documentation.desktop', which is also in package linuxcnc-doc-en 1:2.9.2
I would appreciate any assistance or guidance to resolve this issue.
Thank you.
Last edit: 24 Jan 2024 09:22 by Seger.
  • Moderator
  • Moderator
24 Jan 2024 09:23 #291525 by tommylight
Replied by tommylight on topic Error during install RTAI Kernel on Debian 12
Use the ISO on the downloads page, it is Debian 12 BookWorm with LinuxCNC already installed.
www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso
24 Jan 2024 09:30 #291527 by Seger
Okay, I will try that out. I guess the kernel after installation will be the preempt kernel, but can I install the RTAI kernel with the same steps I mentioned in my first question?
  • Moderator
  • Moderator
24 Jan 2024 12:17 #291542 by tommylight
Install that ISO, then use this to install the RTAI kernel and LinuxCNC
linuxcnc.org/docs/2.9/html/getting-start...#cha:Installing-RTAI
section :
7.2. Installing on Debian Bookworm (with experimental RTAI kernel)
25 Jan 2024 01:46 #291580 by Seger
I've done that, but LinuxCNC is not available. When I tried to update my apt repository using the script in 7.1, I encountered an error:
E: Conflicting values set for option Signed-By regarding source www.linuxcnc.org/ bookworm: /etc/apt/trusted.gpg.d/linuxcnc.gpg.key.binary.gpg != /usr/share/keyrings/linuxcnc.gpg
E: The list of sources could not be read
I also tried the LinuxCNC .deb package directly from the Downloads page, but the Package Installer aborts without any notification.
(www.linuxcnc.org/dists/bookworm/2.9-rt/b...xcnc_2.9.2_amd64.deb)
25 Jan 2024 23:42 - 25 Jan 2024 23:43 #291643 by MDM3D
I also get the same error on linux mint Debian Edition.
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following package was automatically installed and is no longer required:
libgpiod2
Use 'sudo apt autoremove' to remove it.
Suggested packages:
mesaflash
The following NEW packages will be installed:
linuxcnc
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/25.5 MB of archives.
After this operation, 89.8 MB of additional disk space will be used.
(Reading database ... 551179 files and directories currently installed.)
Preparing to unpack .../linuxcnc_1%3a2.9.2_amd64.deb ...
Unpacking linuxcnc (1:2.9.2) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I have already installed the RTAI kernal and booted into it before attempting this command.
Last edit: 25 Jan 2024 23:43 by MDM3D. Reason: Clarity
  • Platinum Member
  • Platinum Member
26 Jan 2024 00:43 #291645 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Error during install RTAI Kernel on Debian 12
Try just installing the Linuxcnc package, after removing the docs package
wget linuxcnc.org/dists/bookworm/2.9-rt/binar...xcnc_2.9.2_amd64.deb
sudo apt install ./linuxcnc_2.9.2_amd64.deb
The issue is with the docs package, which isn't really required for a basic install.
26 Feb 2024 23:40 #294578 by MDM3D
That fixed my issue. Thank you.
25 May 2024 13:36 #301430 by Thayloreing
Replied by Thayloreing on topic Error during install RTAI Kernel on Debian 12
I'm trying to upgrade from linuxcnc 2.8 to 2.9 rtai on Debian 10 and I'm also having the same problem, the strange thing is that I've done this same procedure several times and it always worked, now it doesn't work anymore
25 May 2024 13:48 #301432 by andypugh
Replied by andypugh on topic Error during install RTAI Kernel on Debian 12
What isn't working?
Are you definitely installing matching kernels and linuxcnc packages?
Time to create page: 0.101 seconds
