Error during install RTAI Kernel on Debian 12
2 years 9 months ago #291645 by Cant do this anymore bye all
Try just installing the Linuxcnc package, after removing the docs package
wget linuxcnc.org/dists/bookworm/2.9-rt/binar...xcnc_2.9.2_amd64.deb
sudo apt install ./linuxcnc_2.9.2_amd64.deb
The issue is with the docs package, which isn't really required for a basic install.
2 years 8 months ago #294578 by MDM3D
That fixed my issue. Thank you.
2 years 5 months ago #301430 by Thayloreing
I'm trying to upgrade from linuxcnc 2.8 to 2.9 rtai on Debian 10 and I'm also having the same problem, the strange thing is that I've done this same procedure several times and it always worked, now it doesn't work anymore
2 years 5 months ago #301432 by andypugh
What isn't working?
Are you definitely installing matching kernels and linuxcnc packages?
2 years 5 months ago #301435 by Thayloreing
I like to use Linuxcnc 2.9.2 with Debian 10, so I always did the same installation, I installed the linuxcnc 2.8.4 preent iso and used synaptc to update to 2.9 rtai, it always worked, now when I tried today it gave me a error
E: /var/cache/apt/archives/linuxcnc_1%3a2.9.2_amd64.deb: trying to overwrite '/usr/share/applications/linuxcnc-documentation- es.desktop', which is also in the linuxcnc-doc package -es 1:2.8.4.1.gb7824717b
and does not update
2 years 5 months ago #301437 by Thayloreing
I always used it with kernel 4.19.195, I always downloaded the kernel along with the update, now I didn't do that
Time to create page: 0.133 seconds
