Need help with ethernet installation!
- Holzwurm56
- Thank you received: 10
27 Jan 2024 18:03 #291755
by Holzwurm56
Need help with ethernet installation! was created by Holzwurm56
Hello,
i want to install the newest LinuxCNC with Debian12. I make a bootable USB-Sick and can boot the pc in livemodus. I can connect the pc
to the internet via ethernet. Then i want to install LinuxCNC and the installation process stops by the message " Netzwerk einrichten ".
I test it with 2 desktop pcs and a laptop. I tested lan and wlan, nothing works. Has someone an idea what i can do?
Hans
Hans
- Thank you received: 7488
27 Jan 2024 19:35 - 27 Jan 2024 20:45 #291761
Replied by tommylight on topic Need help with ethernet installation!
Download the ISO from the downloads page, it has everything installed and works in Live mode also.
www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso
Last edit: 27 Jan 2024 20:45 by tommylight. Reason: Added link
- Holzwurm56
27 Jan 2024 20:44 #291763
by Holzwurm56
Replied by Holzwurm56 on topic Need help with ethernet installation!
You think machine control in live-mode without installation?
27 Jan 2024 20:46 #291764
Yes, you can control machines in live mode with the official ISO, but it will not save the config.
You can save the config on a hard drive or another USB drive.
Added link to ISO above.
- Holzwurm56
27 Jan 2024 23:21 #291774
by Holzwurm56
Hello tommylight, Control my lathe in live mode, with a program that crashes when installing? The risk is too great for me.
28 Jan 2024 08:22 #291787
Live mode is for testing only.
Where are you getting stuck? When installing to hdd?
- Holzwurm56
28 Jan 2024 21:21 - 28 Jan 2024 21:23 #291835
by Holzwurm56
I have download Debian 12.4 and create a bootable USB-Stick, than i have install Debian with the usb-stick without any problem.
Then i install lcnc with synaptic. It was not the newest version but 2.9. I think there is a problem with the debian-lcnc-iso.
Last edit: 28 Jan 2024 21:23 by Holzwurm56.
- Thank you received: 4150
29 Jan 2024 18:42 #291915
Replied by rodw on topic Need help with ethernet installation!
The latest version of linuxcnc is not in the main stream Debian.
If you want to install linuxcnc on hardware,
Select the correct option when booting and install on your PC.
This sets up the apt environment
There is nothing defective with the ISO if you follow the intended use.
Why would you use synaptic when the live installer already has the latest version of linuxcnc installed? Its for testing only
Time to create page: 0.124 seconds
