Preparing native Raspberry Pi OS for LinuxCNC
2 years 8 months ago #294823 by rodw
You would be better off looking for debian packaged VNC software here  packages.debian.org/index
It will tell you if there are ARM64 packages but the way debian works, it builds for all platforms
The following user(s) said Thank You: ago_tm
2 years 7 months ago #295521 by ago_tm
I created a kind of step by step instruction for the customisation of the RPI Image Builder: github.com/golyakoff/linux-info/blob/mai...Debian12OS/README.md
Hope I covered the majority of the customization cases in different places of the framework written by rodw.
Please feel free to write your comments :)
2 years 4 months ago #303116 by tjtr33
Hello, I get aurh error on last line of these cmds
cd ~
git clone --depth=1 --branch v2.9.2 github.com/linuxcnc/linuxcnc.git ~/linuxcnc-dev
cd linuxcnc-dev
./debian/configure uspace
mk-build-deps
mv linuxcnc-build-deps_$(cat VERSION)_all.deb ../linuxcnc-build-deps_$(cat VERSION)_all.deb
su -c "apt install ../linuxcnc-build-deps_$(cat VERSION)_all.deb -y"
I checked my pwd, I can login ok
but still get auth err when last l line asks for pwd
i tried to circumvent using
sudo apt install ../linuxcnc-build-deps<tab for autocompletion>
but ended with broken packages
this fails as well, same way
su -c "ls"
help!
tomp tjtr33
2 years 4 months ago #303869 by tjtr33
2024/06/27
re raspberry pi and software stepping:
There are two ways to install LinuxCNC discussed in this thread.
The first is to use an ISO image mentioned in the official getting started guide.
Te second way is to the old a system as described by user aso_tm.
The iso solution users wayland and has no screen capture or synaptic
and makes installing synaptic difficult
Also most LinuxCNC apps appear several times in the menus.
All together, these features made me want to build the system.
The second method (ago_tm)
requires additional flags this true the apt install commands
to overcome not trusted sources errors.
Also, gebrated debs involve permission problems
for some me user who is neither me nor wrote.
Beware that the 'copy me' aid copies the $ prompt too.
Getting the build to complete requires several restarts
The first start will show you the error
and the second will hopefully will succeed after modification.
The changes will be to the last line of the copied multiline command.
But, the bottom line is...
neither solution will give you reasonable software stepping
due to huge latencies, between 3 and 7mS (yes mS)
Using latency-histogram --no-base
with 10 glxgears abd 1 youtube vid
OR one VLC vid. ( similar to ago_tm's testing)
So the raspberry pi( my version for) he's not suited to software stepping
and the contributors to this thread suggest using a hardware step generator.
I ask:
1) iI a hardware step generator is used
are latency test meaningless?
Do those tests identify no constraints on the control system?
2) What steps per second can be acgieved?
( my case would be for an rpi4B 4G)
Thanks tjtr33 / tomp
written with nerd-dictation
huh
2 years 4 months ago #303870 by Cant do this anymore bye all
with su you are required to have\know the root password.
sudo only requires you to know your root password.
Latency can be improved by adding isolcpus=2,3 to the kernel command line.The location of the file that needs to be edited is under different directories of /boot depending if you use a pre made Linuxcnc image or install on top of a Raspberry Pi Foundation image. With the RPi Foundation images I use rasp-config to switch from wayland to X11.
I'm not sure what the exact figures are for mesa hardware stepping are but they are way more then you would ever need/find a stepper driver that could use a pulse train that quick.
Be wary of the DIY projects, they are excellent, but sometimes assembling all the hardware required for voltage level translation, coping with differential signals for encoders can come close to Mesa hardware. If you have experience in this field it can be done, I've been down that track, adjusting Mesa source code to suit a dev board and then designing hardware to suit and getting PCBs made then patching Linuxcnc drivers to work with my DIY stuff.
With regards to the latency tests with hardware stepping the constraints aren't so tight, but there is an upper limit.
If I was to try software stepping my list of candidates would be(also some notes on usable interfaces for the RPi models):
1. An x86 system, 4 core if possible with a RT_PREEMPT kernel, for 2 cores maybe a RTAI kernel. (A PC and a parallel port card can be cheaper than an RPi)
2. A RPi5 as this is overall a faster product than the RPi4, but it wont support hardware stepping via SPI. TLDR; the Linuxcnc driver to access the SPI at the hardware level needs a rewrite. Ethernet hasn't been seen to be a problem.
4. A RPi4 (or even better because of a slightly faster clock an RP-400) but don't expect the the machine to excite the world. Spi interface is an option as is Ethernet is also fine for mesa boards.
Be aware that some DIY SPI based options require a servo & base thread, whereas the 7c81,7c80 & 7i90 do not.
2 years 3 months ago #304468 by tjtr33
Thanks very much.
You tell me severalnew things, esp re: spi.
My trusty pentium4 died recently,
after years of being on lifesupport.
luckily, I have an Rpi4 to try SPI remora MKS masahup.
(and a i686 that I can dictate this to)
(note for oother vision impairted, try nerd-dictation)
again, thanks!
Time to create page: 0.350 seconds
