Trying to install LinuxCNC on Raspberry Pi Zero 2 W
- cgy
01 Mar 2024 15:36 #294850
by cgy
Trying to install LinuxCNC on Raspberry Pi Zero 2 W was created by cgy
I hope this message finds you well. I am currently trying to install LinuxCNC on a Raspberry Pi Zero 2 W for a course requirement. Unfortunately, most of the installation guides I have found online are outdated.The Raspberry Pi's current system version is Debian 11 Bullseye. I have successfully applied real-time patches to the Raspberry Pi, and the system version is as follows:
Linux raspberrypi 6.1.74-rt13-v7 #1 SMP PREEMPT_RT Thu Feb 29 16:17:14 CST 2024 armv7l GNU/Linux.My main issue arises when following the official LinuxCNC build instructions. When I use dpkg-checkbuilddeps, it prompts me with the following error: "dpkg-checkbuilddeps: error: Unmet build dependencies: dh-python python-lxml." However, when I try to install these two packages, I receive an error indicating that the packages cannot be located. I have tried several methods to resolve this issue but have been unsuccessful.I would greatly appreciate any assistance or guidance you can provide on how to resolve this issue. Thank you very much for your time and support.Best regards
- Thank you received: 7488
01 Mar 2024 15:47 #294851
Replied by tommylight on topic Trying to install LinuxCNC on Raspberry Pi Zero 2 W
Did you do
sudo apt update
Before trying to install missing packages?
sudo apt update
- cgy
01 Mar 2024 16:16 #294852
by cgy
Replied by cgy on topic Trying to install LinuxCNC on Raspberry Pi Zero 2 W
Yes, I have already attempted this operation, but unfortunately, it didn't work. I also tried "sudo apt-get install lxml" based on some online suggestions. It showed that I have already installed this package under Python 3, but it seems that what is needed now is lxml for Python 2, which is causing me quite a headache.
Additionally, I can install the dh-python package, but it brings up another issue: "The following packages have unmet dependencies: dh-python : Breaks: python E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages." This results in two other dependencies, python and python-dev, being unable to be detected.
- Thank you received: 4150
01 Mar 2024 21:51 #294866
Replied by rodw on topic Trying to install LinuxCNC on Raspberry Pi Zero 2 W
Sometimes you need to google a bit to find what package to install
Debian 11 support was not great.
A alternative might be to use a Debian Bookworm image instead of the pi raspi.debian.net/tested-images/
They appear to have one for your hardware. You can also look at the daily images if you know what one to use.
You will also need to create a user as it just gives you a root user, then add it to the sudoers group.
the PREEMPT_RT kernel should be able to be installed from the debian repositories
You can install a gui while logged in as the root user with
apt install tasksel
tasksel
then select the XFCE desktop.
If you look at the 2.9 getting linuxcnc doc, there is a script which will install linuxcnc for you without building from source. It may work for you but not sure if you are going to end up with 32 bit or 64 bit.
apt install tasksel
tasksel
01 Mar 2024 21:54 #294867
Here is how to do this on the Raspberry Pi,
docs.google.com/document/d/1S0K-UBlXnsYC...b_0/edit?usp=sharing
BUt to install linuxcnc, try the script I mentioned first.
- Thank you received: 426
02 Mar 2024 01:34 #294878
Replied by Cant do this anymore bye all on topic Trying to install LinuxCNC on Raspberry Pi Zero 2 W
- cgy
02 Mar 2024 07:38 #294885
by cgy
Thank you very much for your answer. I will try to switch to the Bookworm system, but I can only use a 32-bit system because using a 64-bit system on the Zero-2 W causes the core to hang and fail to start after installing preempt-rt.
- cakeslob
- Thank you received: 280
03 Mar 2024 18:31 #295072
by cakeslob
Replied by cakeslob on topic Trying to install LinuxCNC on Raspberry Pi Zero 2 W
Time to create page: 0.155 seconds
