Lcnc on LMDE6 with rt 6.1.0.18/20 -- realtek problem --- solved by krn. 6.10.6
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Sep 2024 15:21 #309914 by bkt
@tommylight ..... html wisiwig is terrible on these sites .... if need to write a structured post and edit again, everytime all goes out of order ....  is possible change wisiwig editor?? think you use ckeditor .... not so used on drupal10 for these things I think .... on drupal8 and 9 have the same "problem" ..... Not check if kunema forum use drupal .... but seems same module.
Sorry everyone for criticism .... hope can be a positive suggestion istead ...
  • Moderator
  • Moderator
11 Sep 2024 15:38 #309916 by tommylight
Write and edit in a text editor of your choice, save, copy the on the forum click on "source" button, then paste.If you add pictures, do that first then click on "insert all" again after pressing source button, then add text.
  • bkt
  • Platinum Member
  • Platinum Member
11 Sep 2024 16:47 #309921 by bkt
yea .... in front of pc. ... any how seems the only solutions .....
Time to create page: 0.103 seconds
