Fatal Error After Computer Crash
- Clarge249
10 May 2024 21:28 #300348
by Clarge249
Fatal Error After Computer Crash was created by Clarge249
We experienced a computer crash and now LinuxCNC is unable to load. Below is the error log and I've attached the ini and hal files.
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.15
Machine configuration directory is '/home/cncuser/linuxcnc/configs/GerberSabre408_Crafted1'
Machine configuration file is 'GerberSabre408_Crafted1.ini'
INIFILE=/home/cncuser/linuxcnc/configs/GerberSabre408_Crafted1/GerberSabre408_Crafted1.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./GerberSabre408_Crafted1.hal
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:03:00.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:03:00.0
Found file(REL): ./custom.hal
Found file(REL): ./vc-p4s.hal
hm2_5i25.0: dropping AnyIO board at 0000:03:00.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
./vc-p4s.hal:2: Warning: File contains DOS-style line endings.
./vc-p4s.hal:25: Pin 'halui.jog.0.plus' was already linked to signal 'jog-x-pos'
1440
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7fed93fe7000
File "/usr/bin/hal_manualtoolchange", line 66, in <module>
nf.start(app); nf.makecommand(app, "_", _)
File "/usr/lib/python2.7/dist-packages/nf.py", line 119, in start
source_lib_tcl(r, "support.tcl")
File "/usr/lib/python2.7/dist-packages/nf.py", line 111, in source_lib_tcl
r.tk.call("source", os.path.join(tcl_libdir, f))
KeyboardInterrupt
Kernel message information:
[ 0.000000] microcode: microcode updated early to revision 0x28, date = 2019-11-12
[ 0.000000] Linux version 4.9.0-17-rt-amd64 (This email address is being protected from spambots. You need JavaScript enabled to view it.) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.290-1 (2021-12-12)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-17-rt-amd64 root=UUID=7db4c91d-478e-4fc6-9457-0538c6d6762b ro quiet usbcore.autosuspend=-1
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000d2180fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000d2181000-0x00000000d2187fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000d2188000-0x00000000d25befff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000d25bf000-0x00000000d29ecfff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d29ed000-0x00000000d7ee3fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000d7ee4000-0x00000000d7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d8000000-0x00000000d875dfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000d875e000-0x00000000d87fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000d8800000-0x00000000d8fadfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000d8fae000-0x00000000d8ffffff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000d9000000-0x00000000da71bfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000da71c000-0x00000000da7fffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000da800000-0x00000000db7fcfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000db7fd000-0x00000000dbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000dd000000-0x00000000df1fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000021fdfffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 3020/0WMJ54, BIOS A19 10/30/2018
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x21fe00 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0000000000 mask 7E00000000 write-back
[ 0.000000] 1 base 0200000000 mask 7FE0000000 write-back
[ 0.000000] 2 base 00E0000000 mask 7FE0000000 uncachable
[ 0.000000] 3 base 00DE000000 mask 7FFE000000 uncachable
[ 0.000000] 4 base 00DD000000 mask 7FFF000000 uncachable
[ 0.000000] 5 base 021FE00000 mask 7FFFE00000 uncachable
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] e820: update [mem 0xdd000000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xdb7fd max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000fd970-0x000fd97f] mapped at [ffff8e95400fd970]
[ 0.000000] Base memory trampoline at [ffff8e9540097000] 97000 size 24576
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] RAMDISK: [mem 0x3483d000-0x36415fff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000F0490 000024 (v02 DELL )
[ 0.000000] ACPI: XSDT 0x00000000D8FEE078 00006C (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 0x00000000D8FFAAC0 00010C (v05 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 0x00000000D8FEE170 00C949 (v02 DELL CBX3 00000014 INTL 20091112)
[ 0.000000] ACPI: FACS 0x00000000DA7FE080 000040
[ 0.000000] ACPI: APIC 0x00000000D8FFABD0 000072 (v03 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 0x00000000D8FFAC48 000044 (v01 DELL CBX3 01072009 AMI 00010013)
[ 0.000000] ACPI: SLIC 0x00000000D8FFAC90 000176 (v03 DELL CBX3 01072009 MSFT 00010013)
[ 0.000000] ACPI: SSDT 0x00000000D8FFAE08 000AD8 (v01 PmRef CpuPm 00003000 INTL 20120711)
[ 0.000000] ACPI: HPET 0x00000000D8FFB8E0 000038 (v01 DELL CBX3 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 0x00000000D8FFB918 00036D (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.000000] ACPI: MCFG 0x00000000D8FFBC88 00003C (v01 DELL CBX3 01072009 MSFT 00000097)
[ 0.000000] ACPI: SSDT 0x00000000D8FFBCC8 003528 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x000000021fdfffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x21fdf9000-0x21fdfdfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x000000021fdfffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009cfff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000d2180fff]
[ 0.000000] node 0: [mem 0x00000000d2188000-0x00000000d25befff]
[ 0.000000] node 0: [mem 0x00000000d29ed000-0x00000000d7ee3fff]
[ 0.000000] node 0: [mem 0x00000000d8000000-0x00000000d875dfff]
[ 0.000000] node 0: [mem 0x00000000d8800000-0x00000000d8fadfff]
[ 0.000000] node 0: [mem 0x00000000d9000000-0x00000000da71bfff]
[ 0.000000] node 0: [mem 0x00000000da800000-0x00000000db7fcfff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000021fdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000021fdfffff]
[ 0.000000] On node 0 totalpages: 2076272
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3996 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 13956 pages used for memmap
[ 0.000000] DMA32 zone: 893140 pages, LIFO batch:31
[ 0.000000] Normal zone: 18424 pages used for memmap
[ 0.000000] Normal zone: 1179136 pages, LIFO batch:31
[ 0.000000] Reserving Intel graphics memory at 0x00000000dd200000-0x00000000df1fffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x1808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009d000-0x0009dfff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009e000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd2181000-0xd2187fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd25bf000-0xd29ecfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd7ee4000-0xd7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd875e000-0xd87fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xd8fae000-0xd8ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xda71c000-0xda7fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdb7fd000-0xdbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdc000000-0xdcffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdd000000-0xdf1fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xdf200000-0xf7ffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.000000] e820: [mem 0xdf200000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] percpu: Embedded 116 pages/cpu s438144 r8192 d28800 u524288
[ 0.000000] pcpu-alloc: s438144 r8192 d28800 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 2043807
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-17-rt-amd64 root=UUID=7db4c91d-478e-4fc6-9457-0538c6d6762b ro quiet usbcore.autosuspend=-1
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 8061428K/8305088K available (6441K kernel code, 1156K rwdata, 2920K rodata, 1692K init, 864K bss, 243660K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Kernel/User page tables isolation: enabled
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=4.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS:33024 nr_irqs:456 16
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3292.293 MHz processor
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 6584.58 BogoMIPS (lpj=13169172)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000009] ACPI: Core revision 20160831
[ 0.006920] ACPI: 4 ACPI AML tables successfully acquired and loaded
[ 0.006938] Security Framework initialized
[ 0.006939] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.006942] AppArmor: AppArmor disabled by boot time parameter
[ 0.007696] Dentry cache hash table entries: 1048576 (order: 12, 16777216 bytes)
[ 0.009685] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.010156] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.010163] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.010361] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.010361] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.010370] mce: CPU supports 9 MCE banks
[ 0.010379] CPU0: Thermal monitoring enabled (TM1)
[ 0.010390] process: using mwait in idle threads
[ 0.010393] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.010393] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.010394] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.010395] Spectre V2 : Mitigation: Full generic retpoline
[ 0.010395] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.010395] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.010396] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.010396] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.010398] SRBDS: Mitigation: Microcode
[ 0.010398] MDS: Mitigation: Clear CPU buffers
[ 0.010672] Freeing SMP alternatives memory: 24K
[ 0.011324] ftrace: allocating 25360 entries in 100 pages
[ 0.027418] smpboot: Max logical packages: 1
[ 0.027484] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.027854] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.067542] TSC deadline timer enabled
[ 0.067544] smpboot: CPU0: Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz (family: 0x6, model: 0x3c, stepping: 0x3)
[ 0.067560] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.067575] ... version: 3
[ 0.067576] ... bit width: 48
[ 0.067576] ... generic registers: 8
[ 0.067577] ... value mask: 0000ffffffffffff
[ 0.067577] ... max period: 00007fffffffffff
[ 0.067578] ... fixed-purpose events: 3
[ 0.067578] ... event mask: 00000007000000ff
[ 0.123630] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.175591] x86: Booting SMP configuration:
[ 0.175592] .... node #0, CPUs: #1 #2 #3
[ 0.266896] x86: Booted up 1 node, 4 CPUs
[ 0.266898] smpboot: Total of 4 processors activated (26338.34 BogoMIPS)
[ 0.269615] devtmpfs: initialized
[ 0.269665] x86/mm: Memory block size: 128MB
[ 0.271298] PM: Registering ACPI NVS region [mem 0xd2181000-0xd2187fff] (28672 bytes)
[ 0.271299] PM: Registering ACPI NVS region [mem 0xda71c000-0xda7fffff] (933888 bytes)
[ 0.271341] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.271355] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.271387] pinctrl core: initialized pinctrl subsystem
[ 0.271492] NET: Registered protocol family 16
[ 0.271645] cpuidle: using governor ladder
[ 0.271682] cpuidle: using governor menu
[ 0.271709] ACPI: bus type PCI registered
[ 0.271710] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.271761] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.271762] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.271767] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[ 0.271841] PCI: Using configuration type 1 for base access
[ 0.271845] dmi type 0xB1 record - unknown flag
[ 0.271926] core: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[ 0.271962] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.272723] HugeTLB registered 1 GB page size, pre-allocated 0 pages
[ 0.272724] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.272838] ACPI: Added _OSI(Module Device)
[ 0.272839] ACPI: Added _OSI(Processor Device)
[ 0.272840] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.272840] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.272996] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.275533] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.277236] ACPI: Interpreter enabled
[ 0.277259] ACPI: (supports S0 S3 S4 S5)
[ 0.277259] ACPI: Using IOAPIC for interrupt routing
[ 0.277278] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.563130] ACPI: Power Resource [FN00] (off)
[ 0.563198] ACPI: Power Resource [FN01] (off)
[ 0.563263] ACPI: Power Resource [FN02] (off)
[ 0.563329] ACPI: Power Resource [FN03] (off)
[ 0.563391] ACPI: Power Resource [FN04] (off)
[ 0.564032] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.564035] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.564467] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 0.564772] PCI host bridge to bus 0000:00
[ 0.564774] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.564775] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.564776] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.564777] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.564777] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.564778] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.564779] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ 0.564780] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ 0.564781] pci_bus 0000:00: root bus resource [mem 0xdf200000-0xfeafffff window]
[ 0.564783] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.564789] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[ 0.564861] pci 0000:00:02.0: [8086:0412] type 00 class 0x030000
[ 0.564868] pci 0000:00:02.0: reg 0x10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.564873] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.564876] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.745130] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[ 0.745137] pci 0000:00:03.0: reg 0x10: [mem 0xf7e14000-0xf7e17fff 64bit]
[ 0.745228] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[ 0.745243] pci 0000:00:14.0: reg 0x10: [mem 0xf7e00000-0xf7e0ffff 64bit]
[ 0.745295] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.745328] pci 0000:00:14.0: System wakeup disabled by ACPI
[ 0.745358] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[ 0.745374] pci 0000:00:16.0: reg 0x10: [mem 0xf7e1e000-0xf7e1e00f 64bit]
[ 0.745429] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.745494] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[ 0.745509] pci 0000:00:1a.0: reg 0x10: [mem 0xf7e1c000-0xf7e1c3ff]
[ 0.745581] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.745615] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.745646] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[ 0.745659] pci 0000:00:1b.0: reg 0x10: [mem 0xf7e10000-0xf7e13fff 64bit]
[ 0.745720] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.745754] pci 0000:00:1b.0: System wakeup disabled by ACPI
[ 0.745783] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[ 0.745838] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.745902] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.745932] pci 0000:00:1c.2: [8086:8c14] type 01 class 0x060400
[ 0.745988] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.746046] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.746075] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[ 0.746131] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.746190] pci 0000:00:1c.3: System wakeup disabled by ACPI
[ 0.746224] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[ 0.746240] pci 0000:00:1d.0: reg 0x10: [mem 0xf7e1b000-0xf7e1b3ff]
[ 0.746315] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.746348] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.746378] pci 0000:00:1f.0: [8086:8c5c] type 00 class 0x060100
[ 0.746521] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[ 0.746533] pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
[ 0.746539] pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
[ 0.746546] pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
[ 0.746552] pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
[ 0.746559] pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
[ 0.746565] pci 0000:00:1f.2: reg 0x24: [mem 0xf7e1a000-0xf7e1a7ff]
[ 0.746596] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.746652] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[ 0.746665] pci 0000:00:1f.3: reg 0x10: [mem 0xf7e19000-0xf7e190ff 64bit]
[ 0.746682] pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
[ 0.746800] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.746871] pci 0000:02:00.0: [104c:8240] type 01 class 0x060400
[ 0.746993] pci 0000:02:00.0: supports D1 D2
[ 0.747023] pci 0000:02:00.0: System wakeup disabled by ACPI
[ 0.755339] pci 0000:00:1c.2: PCI bridge to [bus 02-03]
[ 0.755344] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.755423] pci 0000:03:00.0: [2718:5125] type 00 class 0x110000
[ 0.755447] pci 0000:03:00.0: reg 0x10: [mem 0xf7d00000-0xf7d0ffff]
[ 0.755666] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.755677] pci 0000:02:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.755764] pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000
[ 0.755782] pci 0000:04:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 0.755808] pci 0000:04:00.0: reg 0x18: [mem 0xf7c00000-0xf7c00fff 64bit]
[ 0.755825] pci 0000:04:00.0: reg 0x20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.755912] pci 0000:04:00.0: supports D1 D2
[ 0.755913] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.755951] pci 0000:04:00.0: System wakeup disabled by ACPI
[ 0.771343] pci 0000:00:1c.3: PCI bridge to [bus 04]
[ 0.771346] pci 0000:00:1c.3: bridge window [io 0xe000-0xefff]
[ 0.771349] pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.771353] pci 0000:00:1c.3: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.771942] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.771979] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.772017] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.772054] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.772090] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.772128] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.772164] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.772198] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 10 11 12 14 15)
[ 0.772433] ACPI: Enabled 4 GPEs in block 00 to 3F
[ 0.772504] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.772505] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.772508] vgaarb: loaded
[ 0.772509] vgaarb: bridge control possible 0000:00:02.0
[ 0.772556] PCI: Using ACPI for IRQ routing
[ 0.773723] PCI: pci_cache_line_size set to 64 bytes
[ 0.773764] e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff]
[ 0.773765] e820: reserve RAM buffer [mem 0xd2181000-0xd3ffffff]
[ 0.773766] e820: reserve RAM buffer [mem 0xd25bf000-0xd3ffffff]
[ 0.773767] e820: reserve RAM buffer [mem 0xd7ee4000-0xd7ffffff]
[ 0.773768] e820: reserve RAM buffer [mem 0xd875e000-0xdbffffff]
[ 0.773769] e820: reserve RAM buffer [mem 0xd8fae000-0xdbffffff]
[ 0.773769] e820: reserve RAM buffer [mem 0xda71c000-0xdbffffff]
[ 0.773770] e820: reserve RAM buffer [mem 0xdb7fd000-0xdbffffff]
[ 0.773771] e820: reserve RAM buffer [mem 0x21fe00000-0x21fffffff]
[ 0.773873] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.773878] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.775902] clocksource: Switched to clocksource hpet
[ 0.783082] VFS: Disk quotas dquot_6.6.0
[ 0.783099] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.783169] pnp: PnP ACPI init
[ 0.783250] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.783253] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.783393] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.783394] system 00:01: [io 0xffff] has been reserved
[ 0.783395] system 00:01: [io 0xffff] has been reserved
[ 0.783396] system 00:01: [io 0xffff] has been reserved
[ 0.783398] system 00:01: [io 0x1c00-0x1cfe] has been reserved
[ 0.783399] system 00:01: [io 0x1d00-0x1dfe] has been reserved
[ 0.783400] system 00:01: [io 0x1e00-0x1efe] has been reserved
[ 0.783401] system 00:01: [io 0x1f00-0x1ffe] has been reserved
[ 0.783402] system 00:01: [io 0x1800-0x18fe] has been reserved
[ 0.783403] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.783405] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.783424] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.783463] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.783465] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.783540] system 00:04: [io 0x0a00-0x0a0f] has been reserved
[ 0.783542] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.783581] system 00:05: [io 0x04d0-0x04d1] has been reserved
[ 0.783583] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.783994] system 00:06: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.783996] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.783997] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.783998] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.784000] system 00:06: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.784001] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.784002] system 00:06: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.784003] system 00:06: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.784005] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[ 0.784006] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.784007] system 00:06: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.784008] system 00:06: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.784011] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.784174] pnp: PnP ACPI: found 7 devices
[ 0.790176] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.790187] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
[ 0.790189] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[ 0.790191] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[ 0.790214] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.790215] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[ 0.790216] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.790217] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.790219] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.790220] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.790224] pci 0000:00:1c.0: BAR 14: assigned [mem 0xdf200000-0xdf3fffff]
[ 0.790229] pci 0000:00:1c.0: BAR 15: assigned [mem 0xdf400000-0xdf5fffff 64bit pref]
[ 0.790231] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.790232] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.790235] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.790240] pci 0000:00:1c.0: bridge window [mem 0xdf200000-0xdf3fffff]
[ 0.790243] pci 0000:00:1c.0: bridge window [mem 0xdf400000-0xdf5fffff 64bit pref]
[ 0.790248] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 0.790254] pci 0000:02:00.0: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.790266] pci 0000:00:1c.2: PCI bridge to [bus 02-03]
[ 0.790270] pci 0000:00:1c.2: bridge window [mem 0xf7d00000-0xf7dfffff]
[ 0.790277] pci 0000:00:1c.3: PCI bridge to [bus 04]
[ 0.790279] pci 0000:00:1c.3: bridge window [io 0xe000-0xefff]
[ 0.790283] pci 0000:00:1c.3: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.790287] pci 0000:00:1c.3: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.790292] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.790293] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.790294] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.790295] pci_bus 0000:00: resource 7 [mem 0x000d4000-0x000d7fff window]
[ 0.790296] pci_bus 0000:00: resource 8 [mem 0x000d8000-0x000dbfff window]
[ 0.790297] pci_bus 0000:00: resource 9 [mem 0x000dc000-0x000dffff window]
[ 0.790298] pci_bus 0000:00: resource 10 [mem 0x000e0000-0x000e3fff window]
[ 0.790299] pci_bus 0000:00: resource 11 [mem 0x000e4000-0x000e7fff window]
[ 0.790300] pci_bus 0000:00: resource 12 [mem 0xdf200000-0xfeafffff window]
[ 0.790301] pci_bus 0000:01: resource 0 [io 0x2000-0x2fff]
[ 0.790302] pci_bus 0000:01: resource 1 [mem 0xdf200000-0xdf3fffff]
[ 0.790303] pci_bus 0000:01: resource 2 [mem 0xdf400000-0xdf5fffff 64bit pref]
[ 0.790304] pci_bus 0000:02: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.790305] pci_bus 0000:03: resource 1 [mem 0xf7d00000-0xf7dfffff]
[ 0.790306] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.790307] pci_bus 0000:04: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 0.790308] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.790383] NET: Registered protocol family 2
[ 0.790469] IP idents hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.791290] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.791560] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
[ 0.792134] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.792177] UDP hash table entries: 4096 (order: 7, 524288 bytes)
[ 0.792288] UDP-Lite hash table entries: 4096 (order: 7, 524288 bytes)
[ 0.792400] NET: Registered protocol family 1
[ 0.792410] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.844011] PCI: CLS 64 bytes, default 64
[ 0.844050] Unpacking initramfs...
[ 1.118184] Freeing initrd memory: 28516K
[ 1.118187] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 1.118189] software IO TLB: mapped [mem 0xd3ee4000-0xd7ee4000] (64MB)
[ 1.118470] audit: initializing netlink subsys (disabled)
[ 1.118485] audit: type=2000 audit(1715376316.664:1): initialized
[ 1.118825] workingset: timestamp_bits=40 max_order=21 bucket_order=0
[ 1.120019] zbud: loaded
[ 1.120785] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.120810] io scheduler noop registered
[ 1.120810] io scheduler deadline registered
[ 1.120832] io scheduler cfq registered (default)
[ 1.121385] pcieport 0000:00:1c.0: Signaling PME through PCIe PME interrupt
[ 1.121389] pcie_pme 0000:00:1c.0:pcie001: service driver pcie_pme loaded
[ 1.121422] pcieport 0000:00:1c.2: Signaling PME through PCIe PME interrupt
[ 1.121423] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[ 1.121424] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[ 1.121428] pcie_pme 0000:00:1c.2:pcie001: service driver pcie_pme loaded
[ 1.121463] pcieport 0000:00:1c.3: Signaling PME through PCIe PME interrupt
[ 1.121464] pci 0000:04:00.0: Signaling PME through PCIe PME interrupt
[ 1.121467] pcie_pme 0000:00:1c.3:pcie001: service driver pcie_pme loaded
[ 1.121475] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.121484] pciehp 0000:00:1c.0:pcie004: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
[ 1.121518] pciehp 0000:00:1c.0:pcie004: service driver pciehp loaded
[ 1.121522] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.121535] intel_idle: MWAIT substates: 0x42120
[ 1.121536] intel_idle: v0.4.1 model 0x3C
[ 1.121646] intel_idle: lapic_timer_reliable_states 0xffffffff
[ 1.121762] GHES: HEST is not enabled!
[ 1.121813] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.122157] Linux agpgart interface v0.103
[ 1.122236] AMD IOMMUv2 driver by Joerg Roedel <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 1.122237] AMD IOMMUv2 functionality not available on this system
[ 1.122466] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.125170] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.125197] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.125306] mousedev: PS/2 mouse device common for all mice
[ 1.125338] rtc_cmos 00:02: RTC can wake from S4
[ 1.125467] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 1.125545] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 1.125552] intel_pstate: Intel P-state driver initializing
[ 1.126052] NET: Registered protocol family 10
[ 1.126213] mip6: Mobile IPv6
[ 1.126215] NET: Registered protocol family 17
[ 1.126217] mpls_gso: MPLS GSO support
[ 1.126384] microcode: sig=0x306c3, pf=0x2, revision=0x28
[ 1.126452] microcode: Microcode Update Driver: v2.01 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.126595] registered taskstats version 1
[ 1.126611] zswap: loaded using pool lzo/zbud
[ 1.126641] ima: No TPM chip found, activating TPM-bypass!
[ 1.126642] ima: Allocated hash algorithm: sha256
[ 1.126968] rtc_cmos 00:02: setting system clock to 2024-05-10 21:25:17 UTC (1715376317)
[ 1.127020] PM: Hibernation image not present or could not be loaded.
[ 1.127769] Freeing unused kernel memory: 1692K
[ 1.127769] Write protecting the kernel read-only data: 12288k
[ 1.128247] Freeing unused kernel memory: 1736K
[ 1.129993] Freeing unused kernel memory: 1176K
[ 1.133511] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.144906] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.144965] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.144973] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.176956] ACPI: bus type USB registered
[ 1.177321] usbcore: registered new interface driver usbfs
[ 1.178000] usbcore: registered new interface driver hub
[ 1.178528] usbcore: registered new device driver usb
[ 1.183225] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.184927] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.187310] SCSI subsystem initialized
[ 1.188007] ehci-pci: EHCI PCI platform driver
[ 1.192114] thermal LNXTHERM:00: registered as thermal_zone0
[ 1.192116] ACPI: Thermal Zone [TZ00] (28 C)
[ 1.192343] ehci-pci 0000:00:1a.0: EHCI Host Controller
[ 1.192527] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 1.192538] ehci-pci 0000:00:1a.0: debug port 2
[ 1.195389] thermal LNXTHERM:01: registered as thermal_zone1
[ 1.195390] ACPI: Thermal Zone [TZ01] (30 C)
[ 1.196454] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[ 1.196483] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7e1c000
[ 1.198541] r8169 0000:04:00.0 eth0: RTL8168g/8111g at 0xffff9b79c1475000, b0:83:fe:95:ff:5e, XID 0c000800 IRQ 27
[ 1.198543] r8169 0000:04:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.200055] libata version 3.00 loaded.
[ 1.205617] AVX2 version of gcm_enc/dec engaged.
[ 1.205618] AES CTR mode by8 optimization enabled
[ 1.211934] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.212126] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.212127] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.212129] usb usb1: Product: EHCI Host Controller
[ 1.212130] usb usb1: Manufacturer: Linux 4.9.0-17-rt-amd64 ehci_hcd
[ 1.212130] usb usb1: SerialNumber: 0000:00:1a.0
[ 1.214786] hub 1-0:1.0: USB hub found
[ 1.214796] hub 1-0:1.0: 2 ports detected
[ 1.215321] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[ 1.215365] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.216084] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.216089] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.217166] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009810
[ 1.217170] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.217330] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.217331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.217332] usb usb2: Product: xHCI Host Controller
[ 1.217333] usb usb2: Manufacturer: Linux 4.9.0-17-rt-amd64 xhci-hcd
[ 1.217334] usb usb2: SerialNumber: 0000:00:14.0
[ 1.217429] hub 2-0:1.0: USB hub found
[ 1.217444] hub 2-0:1.0: 10 ports detected
[ 1.218551] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.218554] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.218624] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.218626] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.218627] usb usb3: Product: xHCI Host Controller
[ 1.218628] usb usb3: Manufacturer: Linux 4.9.0-17-rt-amd64 xhci-hcd
[ 1.218629] usb usb3: SerialNumber: 0000:00:14.0
[ 1.218728] hub 3-0:1.0: USB hub found
[ 1.218739] hub 3-0:1.0: 2 ports detected
[ 1.218940] ahci 0000:00:1f.2: version 3.0
[ 1.219144] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x21 impl SATA mode
[ 1.219146] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part ems
[ 1.228780] scsi host0: ahci
[ 1.228933] scsi host1: ahci
[ 1.229038] scsi host2: ahci
[ 1.229109] scsi host3: ahci
[ 1.229177] scsi host4: ahci
[ 1.229245] scsi host5: ahci
[ 1.229283] ata1: SATA max UDMA/133 abar m2048@0xf7e1a000 port 0xf7e1a100 irq 29
[ 1.229283] ata2: DUMMY
[ 1.229284] ata3: DUMMY
[ 1.229284] ata4: DUMMY
[ 1.229285] ata5: DUMMY
[ 1.229287] ata6: SATA max UDMA/133 abar m2048@0xf7e1a000 port 0xf7e1a380 irq 29
[ 1.229601] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 1.229605] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.229614] ehci-pci 0000:00:1d.0: debug port 2
[ 1.233501] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 1.233562] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7e1b000
[ 1.248002] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.248052] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.248053] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.248054] usb usb4: Product: EHCI Host Controller
[ 1.248055] usb usb4: Manufacturer: Linux 4.9.0-17-rt-amd64 ehci_hcd
[ 1.248056] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.248222] hub 4-0:1.0: USB hub found
[ 1.248226] hub 4-0:1.0: 2 ports detected
[ 1.459966] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.463963] usb 2-5: new low-speed USB device number 2 using xhci_hcd
[ 1.495964] usb 4-1: new high-speed USB device number 2 using ehci-pci
[ 1.543070] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.543128] ata6: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.545630] ata1.00: NCQ Send/Recv Log not supported
[ 1.545641] ata1.00: ATA-9: SAMSUNG SSD PM851 2.5 7mm 128GB, EXT08D0Q, max UDMA/133
[ 1.545642] ata1.00: 250069680 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.546291] ata1.00: NCQ Send/Recv Log not supported
[ 1.546333] ata1.00: configured for UDMA/133
[ 1.546516] scsi 0:0:0:0: Direct-Access ATA SAMSUNG SSD PM85 8D0Q PQ: 0 ANSI: 5
[ 1.547660] ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.547662] ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.547664] ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.547931] ata6.00: ATAPI: PLDS DVD+/-RW DS-8ABSH, LD11, max UDMA/133
[ 1.555198] ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[ 1.555211] ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[ 1.555212] ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[ 1.555523] ata6.00: configured for UDMA/133
[ 1.596350] scsi 5:0:0:0: CD-ROM PLDS DVD+-RW DS-8ABSH LD11 PQ: 0 ANSI: 5
[ 1.607584] usb 2-5: New USB device found, idVendor=413c, idProduct=301a
[ 1.607586] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.607587] usb 2-5: Product: Dell MS116 USB Optical Mouse
[ 1.607588] usb 2-5: Manufacturer: PixArt
[ 1.608305] usb 1-1: New USB device found, idVendor=8087, idProduct=8008
[ 1.608306] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.608632] hub 1-1:1.0: USB hub found
[ 1.608784] hub 1-1:1.0: 4 ports detected
[ 1.609094] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.610721] usbcore: registered new interface driver usbhid
[ 1.610722] usbhid: USB HID core driver
[ 1.611322] input: PixArt Dell MS116 USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/0003:413C:301A.0001/input/input3
[ 1.614110] hid-generic 0003:413C:301A.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-0000:00:14.0-5/input0
[ 1.615664] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ 1.615689] sd 0:0:0:0: [sda] Write Protect is off
[ 1.615691] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.615699] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.622657] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7
[ 1.623043] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.632470] sr 5:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.632471] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.632580] sr 5:0:0:0: Attached scsi CD-ROM sr0
[ 1.644485] usb 4-1: New USB device found, idVendor=8087, idProduct=8000
[ 1.644487] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.644829] hub 4-1:1.0: USB hub found
[ 1.644938] hub 4-1:1.0: 6 ports detected
[ 1.727940] usb 2-6: new low-speed USB device number 3 using xhci_hcd
[ 1.790515] random: fast init done
[ 1.792303] PM: Starting manual resume from disk
[ 1.792305] PM: Hibernation image partition 8:7 present
[ 1.792305] PM: Looking for hibernation image.
[ 1.792520] PM: Image not found (code -22)
[ 1.792520] PM: Hibernation image not present or could not be loaded.
[ 1.888643] usb 2-6: New USB device found, idVendor=0d62, idProduct=3f41
[ 1.888645] usb 2-6: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.888646] usb 2-6: Product: HP Wired Desktop 320K Keyboard
[ 1.888647] usb 2-6: Manufacturer: Darfon
[ 1.892892] input: Darfon HP Wired Desktop 320K Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.0/0003:0D62:3F41.0002/input/input4
[ 1.893298] EXT4-fs (sda6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.952156] hid-generic 0003:0D62:3F41.0002: input,hidraw1: USB HID v1.11 Keyboard [Darfon HP Wired Desktop 320K Keyboard] on usb-0000:00:14.0-6/input0
[ 1.956187] input: Darfon HP Wired Desktop 320K Keyboard as /devices/pci0000:00/0000:00:14.0/usb2/2-6/2-6:1.1/0003:0D62:3F41.0003/input/input5
[ 2.016091] hid-generic 0003:0D62:3F41.0003: input,hidraw2: USB HID v1.11 Device [Darfon HP Wired Desktop 320K Keyboard] on usb-0000:00:14.0-6/input1
[ 2.143988] tsc: Refined TSC clocksource calibration: 3292.375 MHz
[ 2.143993] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2f75298baf3, max_idle_ns: 440795322961 ns
[ 2.400482] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.414891] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 2.415061] systemd[1]: Detected architecture x86-64.
[ 2.418799] systemd[1]: Set hostname to <CNCRouterPC>.
[ 2.629288] systemd[1]: NetworkManager-wait-online.service: Cannot add dependency job, ignoring: Unit NetworkManager-wait-online.service is masked.
[ 2.629308] systemd[1]: NetworkManager.service: Cannot add dependency job, ignoring: Unit NetworkManager.service is masked.
[ 2.629318] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 2.629994] systemd[1]: Created slice System Slice.
[ 2.630126] systemd[1]: Created slice system-getty.slice.
[ 2.630187] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.630233] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 2.680829] EXT4-fs (sda6): re-mounted. Opts: errors=remount-ro
[ 2.709800] lp: driver loaded but no devices found
[ 2.718095] ppdev: user-space parallel port driver
[ 2.768182] systemd-journald[257]: Received request to flush runtime journal from PID 1
[ 3.078355] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6
[ 3.078359] ACPI: Power Button [PWRB]
[ 3.078410] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[ 3.078411] ACPI: Power Button [PWRF]
[ 3.143217] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 3.168027] clocksource: Switched to clocksource tsc
[ 3.206849] [drm] Initialized
[ 3.350316] [drm] PipeC fused off
[ 3.350326] [drm] Memory usable by graphics device = 2048M
[ 3.350327] [drm] Replacing VGA console driver
[ 3.352497] Console: switching to colour dummy device 80x25
[ 3.359701] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.359702] [drm] Driver supports precise vblank timestamp query.
[ 3.372417] wmi: Mapper loaded
[ 3.376922] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.413791] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 3.418595] acpi device:60: registered as cooling_device9
[ 3.423045] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input8
[ 3.423404] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[ 3.438086] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 3.444217] fbcon: inteldrmfb (fb0) is primary device
[ 3.487026] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 3.489860] sr 5:0:0:0: Attached scsi generic sg1 type 5
[ 3.521146] Console: switching to colour frame buffer device 240x67
[ 3.540576] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 3.551359] snd_hda_codec_realtek hdaudioC1D2: autoconfig for ALC3220: line_outs=1 (0x1b/0x0/0x0/0x0/0x0) type:line
[ 3.551361] snd_hda_codec_realtek hdaudioC1D2: speaker_outs=1 (0x14/0x0/0x0/0x0/0x0)
[ 3.551363] snd_hda_codec_realtek hdaudioC1D2: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 3.551364] snd_hda_codec_realtek hdaudioC1D2: mono: mono_out=0x0
[ 3.551364] snd_hda_codec_realtek hdaudioC1D2: inputs:
[ 3.551366] snd_hda_codec_realtek hdaudioC1D2: Front Mic=0x1a
[ 3.551367] snd_hda_codec_realtek hdaudioC1D2: Rear Mic=0x18
[ 3.551890] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input9
[ 3.566775] input: PC Speaker as /devices/platform/pcspkr/input/input14
[ 3.581544] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
[ 3.586936] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[ 3.592198] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card1/input12
[ 3.596971] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input13
[ 3.655532] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 3.655533] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.655534] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.655534] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.655535] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.776159] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 3.868352] iTCO_vendor_support: vendor-support=0
[ 3.874154] Adding 8303612k swap on /dev/sda7. Priority:-1 extents:1 across:8303612k SSFS
[ 3.875083] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 3.875538] iTCO_wdt: Found a Lynx Point TCO device (Version=2, TCOBASE=0x1860)
[ 3.885973] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.902426] dell_wmi: Detected Dell WMI interface version 1
[ 3.906212] input: Dell WMI hotkeys as /devices/virtual/input/input15
[ 4.025277] intel_rapl: Found RAPL domain package
[ 4.025279] intel_rapl: Found RAPL domain core
[ 4.025280] intel_rapl: Found RAPL domain uncore
[ 4.025281] intel_rapl: Found RAPL domain dram
[ 4.025282] intel_rapl: RAPL package 0 domain package locked by BIOS
[ 4.025286] intel_rapl: RAPL package 0 domain dram locked by BIOS
[ 4.605478] r8169 0000:04:00.0: firmware: direct-loading firmware rtl_nic/rtl8168g-2.fw
[ 4.678206] r8169 0000:04:00.0 eth0: link down
[ 4.678221] r8169 0000:04:00.0 eth0: link down
[ 4.678263] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.936482] r8169 0000:04:00.0 eth0: link up
[ 6.936486] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 29.024668] random: crng init done
[ 29.024670] random: 7 urandom warning(s) missed due to ratelimiting
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.15
TASK=milltask
HALUI=halui
DISPLAY=axis
hm2: unloading
1440
KeyboardInterrupt
- Thank you received: 5330
10 May 2024 21:36 - 10 May 2024 21:37 #300350
Replied by PCW on topic Fatal Error After Computer Crash
The error is this:
Which is duplicated in your main hal file:
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
Last edit: 10 May 2024 21:37 by PCW.
- Clarge249
10 May 2024 21:48 #300352
by Clarge249
Replied by Clarge249 on topic Fatal Error After Computer Crash
Thank you!
What is the correct way to fix this? Our pendent has not been functioning for a while and I think someone was working on it recently and I bet this problem is unrelated to the crash we had.
10 May 2024 21:57 #300354
You might try commenting out (with a preceeding '#')
the line that loads vc-4ps in your ini file:
[HAL]
HALUI = halui
HALFILE = GerberSabre408_Crafted1.hal
HALFILE = custom.hal
HALFILE = vc-p4s.hal
POSTGUI_HALFILE = postgui_call_list.hal
POSTGUI_HALFILE = vc-postgui.hal
HALUI = halui
[HAL]
HALUI = halui
HALUI = halui
- Clarge249
10 May 2024 21:59 #300355
by Clarge249
That fixed it!
Thank you so much for your quick and helpful responses!!!
Time to create page: 0.344 seconds
