Smoked my spindle - likely my fault
- moretoyswins
- moretoyswins
As to the -ve voltage I was of the understanding that setting hm2_7i96s.0.pwmgen.00.offset-mode to true would give me the 0-10v
- Thank you received: 5334
should not apply negative voltages.
What I would do is this:
7I96S SPIN+ --> +12V
7I96S SPIN- --> GND
7I96S SPINOUT --> SPEED CONTROL
Then set the spindle OUTPUT_SCALE to 12V/10V * 25000 = 30000
and spindle MAX_OUTPUT to 25000
(and offset mode false)
- moretoyswins
- moretoyswins
Long story short test with a DVM were positive, could not test spindle due to the late hour. At "m3 s25000" I am putting out between 9.98v and 9.99v, I hope the fluttering does not effect the Spindle performance.
I ended up with:
OUTPUT_SCALE = 12.27V/10V * 25000 = 30675
The issue is the power supply, currently I have one PSU that supplies both +-5v, +12v, the other PSU I have is 48v for Steppers. the issue is you can only adjust the 5v side, the 12v is only "approximately 12v".
From the manufacture's documents:
Of course you don't find these things out until you go digging.Accurate voltage regulation is not guaranteed if the load does not draw the minimum current.
Looking at the block diagram the reason becomes clear: only Channel 1 (5V) is regulated via a feedback loop. Channel 2 (12V) is open loop and unregulated.So you have to adjust the 5V output with the potentiometer while your intended load is drawing its usual current... and you will get "approximately 12V" on the other output.Also the 12V output will fluctuate depending on current draw on the 5V output.![]()
The 12v side does fluctuate between 12.26v and 12.27v, I used the latter in your formula.
There may be a separate 12v PSU in my future, if I can make space in the controller box, which is currently packed. Should have started with a bigger chassis, but I choose to use an old PC case.
Thanks for all the help, on to the next issue and I will have to test Spindle in daylight hours.
- moretoyswins
Thanks again for all your help!
Even 1% will probably be filtered to much less
by the speed control input circuitry.
