LinuxCNC on Raspberry Pi 5 CPU 3 not running
- Marvin_Maverick
24 May 2024 16:06 #301357
by Marvin_Maverick
LinuxCNC on Raspberry Pi 5 CPU 3 not running was created by Marvin_Maverick
I used this image: rpi-5-debian-bookworm-6.1.61-rt15-arm64-ext4-2023-11-17-1520.img.xz
to set up a Raspberry Pi 5 with LinuxCNC.
So far it worked fine. Thanks a lot to all the people that put this image together!!
Now I discovered, that the third CPU (Number "2") of the Raspberry is not running. When LinuxCNC is started, using "htop", I can see, that the third CPU has no load, it is idleing. In the cmdline.txt there is this entry: isolcpus=2,3 and it seams, that LinuxCNC only uses the fourth (Number "3") CPU.
Is there something that can be done to use all the computing power of the Raspberry Pi 5?
- Thank you received: 426
24 May 2024 17:18 #301360
Replied by Cant do this anymore bye all on topic LinuxCNC on Raspberry Pi 5 CPU 3 not running
2 cores run the day to day stuff
2 cores run the real-time stuff
Without isolating 2 cores latency takes a hit. It’s a common fix for latency on all platforms.
The following user(s) said Thank You: Marvin_Maverick
- Marvin_Maverick
24 May 2024 17:52 - 24 May 2024 18:07 #301361
by Marvin_Maverick
Replied by Marvin_Maverick on topic LinuxCNC on Raspberry Pi 5 CPU 3 not running
The third CPU (Number "2") of the Raspberry is not running.
LinuxCNC ("realtime stuff") only uses Core Number 3 (the fourth)
Is there something that can be done to use both Cores (Number 2 and 3 = third and fourth) for LinuxCNC?
Last edit: 24 May 2024 18:07 by Marvin_Maverick.
24 May 2024 21:16 - 24 May 2024 21:20 #301365
Don't worry about it.
Everything will work fine when running a machine.
Have you tried htop when running gcode and actually running a machine ?
You can modify the isolcpu parameter, it's under the /boot folder in a subfolder, mind tho the boot folder has a different structure to the standard RPi one. It's been a while since I've used my RPi5 since helping Rod put the image together (due to the lack of a SPI driver for Mesa hardware).
Long story short latency will suffer without isolation. And depending how cache is shared between the cores there can be a performance hit by isolating the incorrect pair of CPUs (this was from a long forgotten paper). At the end of the day it's not outright performance this is vital with Linuxcnc but latency. Having a responsive interface and more importantly having latency within spec is all that matters. It's not as if you'll using the machine as a desktop whilst running a machine. Remember it's a single use computer, not a desktop.
Play around with isolating CPUs run some latency tests and see how you go. BTW what hardware are you using to control your machine.
Even on a multi core machine with no cpus isolated if the load doesn't require it you will have cores that are more or less idle.
Last edit: 24 May 2024 21:20 by Cant do this anymore bye all.
- Marvin_Maverick
25 May 2024 15:36 - 25 May 2024 15:42 #301441
by Marvin_Maverick
@cornholio:
Thank you for the reply.
"Have you tried htop when running gcode and actually running a machine ?"
No, so far I only did "dry-tests".
I plan to retrofit a EMCO F1 CNC Woodworker. For this machine I bought a Benezan Tripple Beast ( a long time ago...). My plan is to set up LinuxCNC on a Raspberry Pi 5 to control the Tripplebeast.
My last machine was a portal router (DIY) that was (still is) controlled by DC-Servos with UHU3.0-controllers that I build (also a very long time ago)
Regarding the RP5: I hope I can find time to test the setup on the bench next week.
When I have news, I'll post them here.
Than you for your help.
Last edit: 25 May 2024 15:42 by Marvin_Maverick.
26 May 2024 02:18 #301463
I give up.
- Thank you received: 4154
26 May 2024 07:46 #301473
Replied by rodw on topic LinuxCNC on Raspberry Pi 5 CPU 3 not running
LinuxCNC just running a servo-thread only runs a single Realtime thread. By definition thats gunna run on a single core as you observed. Maybe the base thread runs on a second core but i have never used a base thread.
When you run a ethernet connected device, machine latency is no longer important, its the network latency that limits performance. I think this means we should review how we evaluate PC suitability for LinuxCNC. latancy-histogram gives better results with multiple isolated cores but does that matter at all?
- Marvin_Maverick
29 Mar 2025 13:41 #325274
by Marvin_Maverick
Sorry, I did not want to upset anybody. It is my fault. Sorry.
Time to create page: 0.848 seconds
