I am trying to install linuxCNC into Virtualbox
- claytoncramer
30 May 2024 16:31 - 30 May 2024 20:21 #301858
by claytoncramer
I am trying to install linuxCNC into Virtualbox was created by claytoncramer
I have used v 2.7 in the past with success and it is running on the box that controls my mill. The ony ISO I can find is 2.9 and it has amd in the name. My Lenovo is Intel.
When I try to add a linuxCNC guest in Virualbox, I get Can't run guest install. If I start it, I get "no bootable media".
Here is 2.7.14 ISO. It seems to install. www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
I spoke too soon. It never completes installation. Has anyone done this in Virtualbox?
Last edit: 30 May 2024 20:21 by claytoncramer. Reason: more woe
- Thank you received: 7488
30 May 2024 17:25 #301861
Replied by tommylight on topic I am trying to install linuxCNC into Virtualbox
Almost all Linux versions use AMD64 in the naming to describe the 64BIT versions, all work for Intel, so download and install it.
30 May 2024 17:36 #301864
Deleted the duplicate post.
- Thank you received: 426
31 May 2024 00:58 #301910
Replied by Cant do this anymore bye all on topic I am trying to install linuxCNC into Virtualbox
Just ran through an installation on VirtualBox on a Linux Mint host with a wheezy iso. Everything went fine. No issues. Take note that Wheezy is end of life and latency will be too high to run a machine. To run a machine you need to be running on a physical\real machine not a virtual one.
If you want any help something more than "It never completes installation" is needed.
Time to create page: 0.131 seconds
