Reinstalled LinuxCNC and won't reconnect to mesa board
2 years 5 months ago #302068 by tjones
I was previous using 1.2.9 and I reinstalled linuxCNC using debian 10 buster.   Its a .iso that I burned a while back that has always just worked for me.  I get linux all re-installed with 1.2.8 do the upgrade to 1.2.9, no issues.  It is -rt so I installed 2.9-uspace.  I set my static IP to 10.10.10.10 for the mesa board, I can ping 10.10.10.10 and all is good.  I loaded the preconfigured mill config I was using.  And it appears it won't connect to the board.  I have attached a linuxCNC.report below.  Also added my config.  Tosh-mill is the config I care about.
File Name: linuxcnc-report.txt
File Size:5.53 KB
File Name: ToshCNCBackup.zip
File Size:55.21 KB
2 years 5 months ago #302072 by tommylight
Wrong IP address on the PC, change the PC address to 10.10.10.100 or 10.10.10.11 or whatever at the end, just not 10.
2 years 5 months ago #302074 by tjones
What is the best way to do that?
I tried opening the "/etc/network/interfaces" document. I can edit it, but it won't let me save it.
Found this thread to follow:
forum.linuxcnc.org/38-general-linuxcnc-q...ith-debian-10-buster
2 years 5 months ago #302076 by PCW
You need to launch the editor with root privileges, like
sudo mousepad /etc/network/interfaces
2 years 5 months ago #302078 by tommylight
How did you set it to 10.10.10.10 ?
Using Network Manager probably, so use that or as PCW advised, but not both.
2 years 5 months ago #302082 by tjones
Yes, I used network manager. I set the static ip4 for the ethernet connect to 10.10.10.10. I have since tried change that to a 10.10.10.X and I get the same error. I can ping and get it, but can't load linuxCNC to it.
I did just change the network interfaces document, I get the same error and I changed it back. For me the enp3s0
Time to create page: 0.360 seconds
