Linuxcnc shutting down with error
02 Jun 2024 15:05 #302163 by kmeld
Linuxcnc shutting down with error was created by kmeld
I just have set up my XYZ cnc with Pncconf wizzard.
Linuxcnc is not starting but shutting down with an error.
Please hep.
This is what it gives out:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/km/linuxcnc/configs/CNC_XYZ_01'
Machine configuration file is 'CNC_XYZ_01.ini'
INIFILE=/home/km/linuxcnc/configs/CNC_XYZ_01/CNC_XYZ_01.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./CNC_XYZ_01.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:87:e2
hm2_eth: discovered 7I96S
hm2/hm2_7i96s.0: Low Level init 0.15
board fails HM2 registration
hm2_eth: in hm2_eth_reset
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2/hm2_7i96s.0: num_sserials references 2 instances, but only 1 are available, not loading driver
hm2/hm2_7i96s.0: failed to parse Module Descriptor 7
hm2_eth: rtapi_app_main: Invalid argument (-22)
./CNC_XYZ_01.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./CNC_XYZ_01.hal:9: /usr/bin/rtapi_app exited without becoming ready
./CNC_XYZ_01.hal:9: insmod for hm2_eth failed, returned -1
2210
Stopping realtime threads
Unloading hal components
KM
02 Jun 2024 15:15 #302164 by PCW
Replied by PCW on topic Linuxcnc shutting down with error
Sounds like you did not select the basic 7I96S firmware (7i96s_d)
when you started LinuxCNC (the default is 7i96s_7I74 which has 2 sserial ports)
This default choice has been fixed on the latest pncconf but for the current
version you need to select 7i96s_d firmware.
02 Jun 2024 15:20 #302165 by kmeld
Replied by kmeld on topic Linuxcnc shutting down with error
changing firmware to 7i96s_d helped.
For anyone who has the same problem.
After selecting this firmware you have to click "accept component changes" in the bottom of the window
KM
Time to create page: 0.181 seconds
