Complete clueless idiot: please help me install linuxcnc v2.6.11
22 Jun 2024 21:32 - 22 Jun 2024 21:38 #303569 by ffffrf
hello, I am trying to download linuxcnc 2.6.11 which is the version used by the sherline lathe that I will get in a couple of weeks. They charge 900 dollars for a computer with the linuxcnc which is absurd so I wanted to try doing it on my own. I got a dell optiplex 7010 and downloaded the latest version of ubuntu.
I then tried to download linuxcnc 2.6.11 via the terminal with many errors every time (with the help of chatGPT) with the following commands:
sudo add-apt-repository 'deb linuxcnc.org/ buster base 2.7-rtai'
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-key 3CB9FD148F374FEF
sudo apt-get update
sudo apt-get install linuxcnc
I tried using precise base and other bases along with the associated keys
each time I get errors such as "unable to locate linuxcnc" or "skipping acquired file XXX...does not have the component 2.7-rtai" or ""the following signatures couldnt be verified because the public key is not available: NO_PUBKEY XXXXX"
edit: another error is "the repository 'linuxcnc.org buster inrelease' is not signed. updating from such a repository cant be done securely and is disabled by default
Can someone please please help me with some idiot-proof instructions on how to download this older version?
Last edit: 22 Jun 2024 21:38 by ffffrf.
22 Jun 2024 22:24 #303572 by jimmyrig
I haven't been around enough to know 2.6 but 2.7 is available at linuxcnc.org/iso as an iso. Might try that?
It shouldn't be that hard to get it running on 2.9.2 instead of 2.6.
Do you have the ini and hal files?
22 Jun 2024 22:33 #303573 by ffffrf
I do not have the .ini or hal files onhand as the lathe has not arrived yet, however, I believe sherline has it posted on their website here: sherline.com/wp-content/uploads/2016/04/...027070277.1718319041
I do think that I will end up just trying to get it to run on a later version of linuxcnc, perhaps I will try downloading 2.7 first to check it out
22 Jun 2024 23:42 #303578 by tommylight
2.6 stuff should work "as is" on 2.7 as the only major change i can think of back then was the new trajectory planner and look-ahead.
  • Platinum Member
  • Platinum Member
23 Jun 2024 02:32 - 23 Jun 2024 02:35 #303589 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Complete clueless idiot: please help me install linuxcnc v2.6.11
I'd try an install of Wheezy, it'll have 2.7 but should be able to be made to work.
I'd be wary of AI and the like, you know with "d1v3r5ty is strength" mumbo jumbo. If it finds enough information saying the sky is Cheddar Cheese that's what it'll tell ya.
On a side note, has anyone seen "AI sign language", think about it, how often does AI get hands right ?
Last edit: 23 Jun 2024 02:35 by Cant do this anymore bye all.
Time to create page: 0.146 seconds
