Try to install LInuxCNC without image
- zjjxxsh
24 Jun 2024 17:20 - 24 Jun 2024 17:22 #303706
by zjjxxsh
Try to install LInuxCNC without image was created by zjjxxsh
I'm trying to make LinuxCNC working on OrangePi 3b and I'm using Debian12 bookworm(from orange pi official website).
It's a minimal linux with GUI I guess.
Now I'm trying to install RT(RTAI or PREEMP I'm not sure) and LinuxCNC 2.9.2
I'm try to figure out the best (right) way to do.....
I tried to use apt and dpkg(install deb file), but failed, none of them work...
Last edit: 24 Jun 2024 17:22 by zjjxxsh.
- royka
- Thank you received: 135
24 Jun 2024 22:15 - 24 Jun 2024 22:33 #303718
by royka
Replied by royka on topic Try to install LInuxCNC without image
To install an rt kernel for a SBC you need to patch/compile it yourself in most cases.
This rt-kernel is for the RK3588 (Orange Pi 5), you could give it a try, but there is a chance that it won't boot because of missing drivers:
drive.google.com/drive/folders/1JglCIPKv...roZcjOvr?usp=sharing
Here is the source that's already patched (rt)
github.com/orangepi-xunlong/linux-orange...ge-pi-5.10-rk35xx-rt
Linuxcnc 2.9.2
www.linuxcnc.org/dists/bookworm/2.9-uspa...pace_2.9.2_arm64.deb
www.linuxcnc.org/dists/bookworm/2.9-uspa...-dev_2.9.2_arm64.deb
Linuxcnc 2.9.2
Last edit: 24 Jun 2024 22:33 by royka.
