Spindle/router won't run
- Irritant
25 Jun 2024 19:02 #303774
by Irritant
Spindle/router won't run was created by Irritant
Trying to get the router to run. I have tried everything there is in the config settings. The controller is Unity from Probotix and it says pin 14. Or I may be doing something wrong else where.
Spindle ON
Spindle PWM
Spindle CCW
Spindle CW
Spindle Brake
Spindle ON
Spindle PWM
Spindle CCW
Spindle CW
Spindle Brake
- B.Reilly01
- Thank you received: 24
27 Jun 2024 16:22 - 27 Jun 2024 16:26 #303908
by B.Reilly01
Replied by B.Reilly01 on topic Spindle/router won't run
Could you post your HAL and INI files?
EDIT: I see now you're using a controller I'm unfamiliar with, but hopefully can still help. What VFD are you running? Which Unity controller is it?
Last edit: 27 Jun 2024 16:26 by B.Reilly01.
