Fresh Rpi4 Install w/7i96s Invalid Bitfile Header
- Dmclements
13 Jul 2024 08:44 #305058
by Dmclements
Fresh Rpi4 Install w/7i96s Invalid Bitfile Header was created by Dmclements
Had this stuff for couple years but everytime I try and get something setup I run into problems and then just put it back in a box and back on a shelf.
But now I have an actual need to get this going to replace a 10yr old CandCNC packaged system.
Tried flashing the 7i96s_dpl firmware.
Returns the error: Invalid bitfile header!
The couple other posts I found mentioned updating mesaflash. My current mesaflash version is 3.4.9, and I’m not savy enough with reading github to know if thats up to date or not.
Not to mention network manager seems to be missing on the pi image, or at least there is no straightforward way of launching the gui for it from any menu I’ve looked in. So currently no internet connection on the pi, will work on that tomorrow.
- Thank you received: 426
13 Jul 2024 12:41 - 13 Jul 2024 12:53 #305071
Replied by Cant do this anymore bye all on topic Fresh Rpi4 Install w/7i96s Invalid Bitfile Header
You are correct there is no network manager.
If you want the latest mesaflash you will need to build it from source following the instructions on the GitHub page. Current version is 3.5.9
Last edit: 13 Jul 2024 12:53 by Cant do this anymore bye all. Reason: I'm stupid
13 Jul 2024 12:58 #305072
Run menu-config from the command line to setup a wireless network.
The following user(s) said Thank You: Dmclements
- Dmclements
13 Jul 2024 16:19 #305091
by Dmclements
Replied by Dmclements on topic Fresh Rpi4 Install w/7i96s Invalid Bitfile Header
Updated to 3.5.9, still get Invalid bitfile header!
Assume the firmware on the 7i96s is still the default, dont think I had any reason to attempt to change it any time I tried setting something up before. I do get a reply with the —readhmid.
The dpl firmware just turns my spindle encoder header back into general I/O, right?
- Dmclements
13 Jul 2024 17:00 #305094
by Dmclements
Scratch that, my fault, used the wrong file extension.
- Thank you received: 7488
13 Jul 2024 17:02 #305095
Any Mesa firmware, if you do not use a module in hal, will leave the pins as normal IO.
Just do not load the encoder and use encoder pins as normal.
Beware those are only 5V pins.
Replied by tommylight on topic Fresh Rpi4 Install w/7i96s Invalid Bitfile Header
No, the dpl firmware should be for plasma, so it make 3 single input encoders as it needs only encoder velocity to function.
- Thank you received: 4150
13 Jul 2024 21:42 #305110
Please follow the instructions in man hm2_eth to set an IP address for your connection to your mesa card
Replied by rodw on topic Fresh Rpi4 Install w/7i96s Invalid Bitfile Header
Please read the notes on the download page to set up your wifi. Network manager adds latency.Not to mention network manager seems to be missing on the pi image, or at least there is no straightforward way of launching the gui for it from any menu I’ve looked in. So currently no internet connection on the pi, will work on that tomorrow.
