2.9.3 ISO Issue
2 years 3 months ago - 2 years 3 months ago #305781 by rodw
2.9.3 ISO Issue was created by rodw
I ran the 2.9.3 installer today and noticed it was installing an old version of linuxcnc.
I've sent a PR to the powers that be that should fix it but in the meantime if you are using 2.9.3 please enter these commands at install time
sudo apt update sudo apt upgrade
This will upgrade to 2.9.3
Last edit: 2 years 3 months ago by rodw.
The following user(s) said Thank You: Sparkman61
2 years 3 months ago #305845 by sprintertrd
Replied by sprintertrd on topic 2.9.3 ISO Issue
Hi Rod,
I got caught by this while testing JT's config tool!
2 years 3 months ago #305849 by rodw
Replied by rodw on topic 2.9.3 ISO Issue
Hi Rod,
Annoying! Ozzyrob has tested my ISO now and it worked. Feel free to grab this
drive.google.com/file/d/1LMwTa6jREfzxM2Z...WVZ/view?usp=sharing
Once Andy is back on deck, I'm hoping he'll be able to update the downloads page image
2 years 3 months ago #305858 by PCW
Replied by PCW on topic 2.9.3 ISO Issue
There's a little typo in the Mesa section:
  1. Ping the mesa card to confirm it's all working
    ping 10.10.10.1
(should be 10.10.10.10)
Also the network setup stuff (other than perhaps the IP address)
also applies to any other UDP connected device (Remora on EC500 etc)
2 years 3 months ago #305865 by rodw
Thanks Peter. I have updated this document which explains how to get the most out of your PC hardware when using Bookworm or Trixie.
docs.google.com/document/d/1jeV_4VKzVmOI...diY/edit?usp=sharing
2 years 3 months ago - 2 years 3 months ago #306287 by rdtsc
Replied by rdtsc on topic 2.9.3 ISO Issue
I think I was able to update 2.9.2 to 2.9.3 successfully using sudo apt update.  However, today I'm getting a key error:
Get:7 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease [1,575 B] Hit:8 https://www.linuxcnc.org bookworm InRelease                         Err:7 http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease   The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org> Fetched 1,575 B in 3s (564 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done All packages are up to date. W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org> W: Failed to fetch http://download.opensuse.org/repositories/science:/EtherLab/Debian_12/./InRelease  The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org> W: Some index files failed to download. They have been ignored, or old ones used instead.
This key error is really odd because that repo is not listed in /etc/apt/sources.list.  Oh wait, found it under /etc/apt/sources.list.d/ighvh.sources. Seems it may have something to do with our  EtherCAT?  build.opensuse.org/projects/science:EtherLab/prjconf
Looking further, they have a page for the key:  build.opensuse.org/projects/science:EtherLab/signing_keys   and a link there to download an "armored version" of a supposedly newer key (says it now expires in two years.)
Thinking maybe if that key were updated, things would improve, researched how to add it and did the following:
1. Downloaded the latest `science_EtherLab_key.gpg` to `~/Downloads` 2. cd there, then `gpg --dearmor science_EtherLab_key.gpg`, which created a `science_EtherLab_key.gpg.gpg` file. 3. `su` to temporarly be root, do `cp science_EtherLab_key.gpg.gpg /usr/share/keyrings/etherlab-archive-keyring.gpg` which copies the file into the appropriate system folder. 4. `exit` to quit root.  Try `sudo apt update` again: nope, keysig still invalid.
As a temporary work-around (I'm not using EtherCAT), `sudo mv /etc/apt/sources.list.d/ighvh.sources /etc/apt/sources.list.d/ighvh.sources.disabled` will disable that source and the resulting error. But this should be investigated properly for the next .iso (if it hasn't already.)
Last edit: 2 years 3 months ago by rdtsc.
Time to create page: 0.328 seconds
