PIN Allocation another search for answers
27 Jul 2024 17:41 #306184 by Irritant
Hi, I am not getting any help on this forum so I thought someone may have had this issue and hopefully found a cure.
The problem:
My new install seems okay but LinuxCNC will not turn the spindle (Bosch router) on. The info for my Probotix Unity controller says pin 14 is the spindle.
I select his and/or invert and it does not work and many others. I have attached the ini and hal files. The date on the file is when I started on this installation, pretty much full time. Right now I have it plugged into a power bar and I flip on and off.
I had a problem where the axis would not move. I was told the change the table size and it worked. So somehow the table size setting are interconnected with the ability to move.
27 Jul 2024 18:15 - 27 Jul 2024 18:16 #306187 by Aciera
Replied by Aciera on topic PIN Allocation another search for answers
Well frankly, as somebody who has tried to help you several times on this very forum I find this a little hard to take. Instead of answering questions about your setup or following the advice you're given you just go and open a new topic asking the same question all over again. It's like yelling into a black hole.
I'm going to give this one more shot in the dark and then I'm done:
in your hal file change this:
net spindle-on => parport.0.pin-14-out
to this:
net spindle-on <= spindle.0.on => parport.0.pin-14-out
Last edit: 27 Jul 2024 18:16 by Aciera.
The following user(s) said Thank You: tommylight, Cant do this anymore bye all
27 Jul 2024 18:39 #306188 by tommylight
Replied by tommylight on topic PIN Allocation another search for answers
You are not helping yourself.
Go back and read your posts, then come back and tell us they are OK.
You can not, as they are from extremely short with absolutely no information to go on, to plain ignoring what info we asked you to provide, to refusing to test what was proposed to you.
The following user(s) said Thank You: Cant do this anymore bye all
  • Platinum Member
  • Platinum Member
27 Jul 2024 18:49 #306189 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic PIN Allocation another search for answers
Considering this is the second thread regarding the same issue......
Honestly the topic heading has no relation to the issue at hand.
Having read the previous topics of the OP plenty have tried to answer, so help has been at hand. With a bit of levity thrown in.
27 Jul 2024 18:54 #306190 by tommylight
Nope, it is the 5'th topic
forum.linuxcnc.org/forum/search?searchus...ritant&childforums=1
  • Platinum Member
  • Platinum Member
27 Jul 2024 22:50 #306205 by Cant do this anymore bye all
You guys are saints.
I often wonder if some people should use anything more complicated than a knife & fork.
28 Jul 2024 00:40 #306211 by Irritant
Replied by Irritant on topic PIN Allocation another search for answers
Hi Guys,
I have it working. Thanks very much for providing the answer to this problem.
Cheers!
Time to create page: 1.546 seconds
