Computer crashing
12 Aug 2024 15:54 #307556 by RLA
Computer crashing was created by RLA
Hi..trying to switch from Mach 3 on Windows XP ....I have the following on same PC but have wiped out Windows and Mach 3 and have only:
Debian GNU/Linux 12 (bookworm)
64 bit
xfce version 4.18
GTK Version 3.24.38
Kernel Version 6.1.0-23-rt-amd64
cpu Intel core 2 cpu 6400 @ 2.13 ghz x 2
Memory 3.8 GiB
GPU Mesa Intel 965Q (384.0 MiB)
and keep having linux stop working and bring me to login after a few changes on screen like open another file or open another application or even resize window..
Will be thankful for any help!!..
12 Aug 2024 16:17 #307561 by tommylight
Replied by tommylight on topic Computer crashing
Open a terminal and type while LinuxCNC is running
sensors
What are the temperatures shown?
Then, reboot and enter the BIOS and check what the voltages are in the "hardware monitor" section.
12 Aug 2024 16:23 #307562 by RLA
Replied by RLA on topic Computer crashing
I get 55 C
54 C
12 Aug 2024 16:29 #307563 by RLA
Sorry..I am not seeing voltages.. probably in wrong spot..?
12 Aug 2024 19:35 - 12 Aug 2024 19:36 #307585 by Mecanix
Replied by Mecanix on topic Computer crashing
Have a look into /var/log/syslog and see if you can find anything time-relevant to your issue(s).
Last edit: 12 Aug 2024 19:36 by Mecanix.
The following user(s) said Thank You: RLA
  • Platinum Member
  • Platinum Member
13 Aug 2024 08:09 #307616 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Computer crashing
I've given up on the core machines, personally not worth the time or effort mucking around with.
One thing that may help is taking the PC apart and cleaning it.
13 Aug 2024 14:14 #307635 by RLA
I tried log path in terminal and got  "no such file or directory'??
Time to create page: 0.123 seconds
