- LinuxCNC
- Installing LinuxCNC
- I need to downgrade from 2.9.2 to 2.5.0 to run our old configs/ hal files
- Crimznn
23 Aug 2024 17:18 #308480
by Crimznn
I need to downgrade from 2.9.2 to 2.5.0 to run our old configs/ hal files was created by Crimznn
our old pc broke we sent it in to get fixed and overnighted a new one but it won't run I/O through the extra parport to the plc, I need to remove 2.9.2 and find the download for 2.5.0 or copy it from our other router pc I need some guidance mostly as far as the re-installation process and where I can find a repo or source to get 2.5.0
- Thank you received: 7488
23 Aug 2024 17:31 #308485
Replied by tommylight on topic I need to downgrade from 2.9.2 to 2.5.0 to run our old configs/ hal files
2.5 will most probably not run on new Linux distros, mostly because of huge changes Python made, and other stuff.
But there are always the original ISO for download, thanks to some very nice folks making it possible
2.5 should be in the 8.04 version of Ubuntu
www.linuxcnc.org/iso/ubuntu-8.04-desktop-emc2-aj13-i386.iso
There is also the 10.04 version that should come with 2.7
www.linuxcnc.org/iso/ubuntu-10.04-linuxcnc3-i386.iso
The following user(s) said Thank You: Crimznn
- Crimznn
23 Aug 2024 17:37 - 23 Aug 2024 19:27 #308487
by Crimznn
Replied by Crimznn on topic I need to downgrade from 2.9.2 to 2.5.0 to run our old configs/ hal files
where can I get 2.5.0 after installing that image I have another older pc with it on there I just don't know the process to transfer it, I'll try that image with 2.7 and see if that works better
not finding the Linuxcnc in either they just seem like disk images no linuxcnc packages embedded if anyone has or knows a repository with the older versions please link them below
Last edit: 23 Aug 2024 19:27 by Crimznn. Reason: misunderstood reply, understood links don't seem to contain linuxcnc
23 Aug 2024 21:32 #308496
Those are full images with LinuxCNC included, they have to be burned to a USB then installed on the PC.
If the old hal files do not have any special added functionality, they should work in new versions of LinuxCNC and there is an included wizard that does the modifications automatically when you first run the old configs.
23 Aug 2024 21:34 #308497
Actual debs are still here:
linuxcnc.org/dists/lucid/linuxcnc2.5/binary-i386/
- LinuxCNC
Time to create page: 0.135 seconds
