7c80 no communication between rpspi 4
- Mr_rookie
30 Aug 2024 21:44 - 30 Aug 2024 21:46 #309055
by Mr_rookie
Replied by Mr_rookie on topic 7c80 no communication between rpspi 4
I tried
enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
everything is working now.
i download linuxcnc_2.9.3_amd64.deb for raspberry pi 4 and they are working. thanks!!
thanks guys for your help!!
Thanks all you guys for your help.
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
Last edit: 30 Aug 2024 21:46 by Mr_rookie.
- Thank you received: 426
31 Aug 2024 02:25 #309068
Replied by Cant do this anymore bye all on topic 7c80 no communication between rpspi 4
Just for completeness what actual file did you edit to enable the spi interfaces ?
Was it:
/boot/firmware/config.txt <-This should not exist on the Linuxcnc image, neither directory or file. Unless the user creates it.
or
/boot/broadcom/config.txt <--This should be the file
Was it:
or
- elovalvo
- Thank you received: 127
31 Aug 2024 06:32 #309073
by elovalvo
AMD64 and Raspberry Pi 4??
everything is working now ....
I really think it's a miracle!!!
Replied by elovalvo on topic 7c80 no communication between rpspi 4
I tried ...
- Mr_rookie
08 Sep 2024 16:49 #309678
by Mr_rookie
www.linuxcnc.org/dists/bookworm/2.9-uspa...pace_2.9.2_arm64.deb
arm64.
yes, but if you are looking get access remotely you may have slow UI.
systemctl disable lightdm that work in my case works perfectly.
arm64.
- Mr_rookie
08 Sep 2024 16:52 #309679
by Mr_rookie
arm_64bit=1
initramfs initrd.gz followkernel
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
# camera
#start_x=1
#gpu_mem=128
# automatically load overlays for detected cameras
#camera_auto_detect=1
# automatically load overlays for detected DSI displays
#display_auto_detect=1
# uncomment to overclock: www.tomshardware.com/how-to/overclock-any-raspberry-pi
#arm_freq=
#gpu_freq=
#core_freq=
#over_voltage=
#force_turbo=1
# uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
# uncomment this to enable infrared communication.
dtoverlay=gpio-ir,gpio_pin=17
dtoverlay=gpio-ir-tx,gpio_pin=18
# additional overlays and parameters are documented /boot/overlays/README
# enable audio (loads snd_bcm2835)
dtparam=audio=on
# enable uart
enable_uart=0
# disable wifi and bluetooth
#dtoverlay=disable-wifi
#dtoverlay=disable-bt
#dtoverlay=pi3-disable-wifi
#dtoverlay=pi3-disable-bt
#dtoverlay=disable-wifi-pi5
#dtoverlay=disable-bt-pi5
# remove test rainbow
disable_splash=1
# disables the warning overlays
avoid_warnings=1
# gpio fan (headers)
#dtoverlay=gpio-fan,gpiopin=12,temp=55000,hyst=2000
[cm4]
otg_mode=1
[pi4]
dtoverlay=vc4-kms-v3d,cma-512
#dtoverlay=vc4-kms-v3d-pi4
#dtoverlay=vc4-fkms-v3d
max_framebuffers=2
arm_boost=1
#disable_fw_kms_setup=1
[pi5]
#dtoverlay=vc4-kms-v3d-pi5
max_framebuffers=0
arm_boost=1
usb_max_current_enable=1
# pwm fan
#dtparam=fan_temp0=50000
#dtparam=fan_temp0_hyst=2000
#dtparam=fan_temp0_speed=75
#dtparam=fan_temp1=55000
#dtparam=fan_temp1_hyst=2000
#dtparam=fan_temp1_speed=125
#dtparam=fan_temp2=60000
#dtparam=fan_temp2_hyst=3000
#dtparam=fan_temp2_speed=175
#dtparam=fan_temp3=65000
#dtparam=fan_temp3_hyst=3000
#dtparam=fan_temp3_speed=250
I remove the # to activate this line
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
#hdmi_safe=1
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#sdtv_mode=2
# camera
#start_x=1
#gpu_mem=128
#arm_freq=
#gpu_freq=
#core_freq=
#over_voltage=
#force_turbo=1
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
# enable uart
enable_uart=0
disable_splash=1
avoid_warnings=1
[cm4]
otg_mode=1
[pi4]
max_framebuffers=2
arm_boost=1
[pi5]
max_framebuffers=0
arm_boost=1
# pwm fan
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
Time to create page: 0.296 seconds
