Riocore setup from scratch for dummies
- epineh
- Thank you received: 27
01 Sep 2024 10:51 #309138
by epineh
Riocore setup from scratch for dummies was created by epineh
Hi everybody, as the name suggests this is a guide for people wanting to install and start playing around with Riocore.
For those that don't know anything about Riocore you can read through the original thread :
www.forum.linuxcnc.org/18-computer/49142...d-on-fpga-ice40-ecp5
This guide is aimed at people that aren't linux guru's, that want to have a try at this awesome LinuxCNC software/hardware and that might struggle like I did...for weeks...to install it and get it going.
Credit to meister, the guy behind it all, he has done an impressive job of getting all this going.
Another credit to ColdTurkey, his idea of using the LinuxCNC live install to setup software/hardware in the Remora thread is what I based my approach on, this way everybody has the closest starting point possible.
This guide will focus on getting everything going for the Gowin Tang Nano FPGA, and meister's Tangoboard, once you have this going you can select other FPGA's and boards as you wish. You will most likely need to change the FPGA programming side of things with other FPGA's.
OK lets begin...
This is for a normal PC, I will have a look at a Raspberry Pi install sooner or later hopefully.
Download and install the latest live install of Linuxcnc, then open a terminal
sudo apt install git
open firefox, skip all start steps, start browsing, google search gowin eda
open page, (first link for me) create account, only email and password required
once logged in, select support, then Gowin EDA Home, then Download Gowin EDA
select software for Linux tab
select the one that says education, (click over to the right)
(at the time of writing this it is the 7th option down)
open File system, navigate to Downloads, right click and select extract to
click on the little folder icon and select Home then extract
go to the folder in file system, right click rename folder to gowin
its easier to type out later
open terminal, enter these one at a time :
git clone github.com/multigcs/riocore.git
sudo apt install python3-pip
sudo apt install python3-yaml
sudo apt install python3-graphviz
sudo apt install openfpgaloader
sudo apt install python3-pyqtgraph
That last one takes a while to install
Now we setup the USB programming :
in terminal still,
cd gowin/Programmer/bin
once you are in that folder type and enter :
sudo ./Gowin_USB_Cable_Installer.sh
sudo make
reboot machine
open terminal
type and enter :
export PATH=$PATH:home/your_user_name/gowin/IDE/bin
in my case my user account is "me" so I type:
export PATH=$PATH:/home/me/gowin/IDE/bin
export PATH=$PATH:/home/me/riocore/bin
change to the riocore directory
cd riocore
now type
PYTHONPATH=. bin/rio-setup riocore/configs/Tangoboard/config.json
This should get you up and running, now there is lots to learn about setting up a machine but hopefully this will take the heartache out of starting.
Now things can be a little weird, I believe the Tang Nano needs to be plugged in at reboot, sometimes it won't flash properly, I cannot honestly say I have got it 100% sorted but if anybody finds a better solution we can edit this to suit.
Good luck
Russell.
OK lets begin...
in terminal still,
sudo make
reboot machine
open terminal
type and enter :
cd riocore
now type
Good luck
Russell.
The following user(s) said Thank You: kostas, cncnoel, meister, Cold Turkey, kzali, mBender, onceloved
- kzali
- Thank you received: 12
07 Sep 2024 03:45 #309536
by kzali
Replied by kzali on topic Riocore setup from scratch for dummies
Hi
Oliver has made some .deb packages, presumably, to setup the reqiured tool chains and packages. Any instructions on usage for us dummies and does the package take away some of the steps defined above?
- meister
- Thank you received: 502
07 Sep 2024 07:18 #309542
by meister
Replied by meister on topic Riocore setup from scratch for dummies
I would prefer the route described above,
it's easier to always be up to date via git.
The most complicated part of the installation is the toolchain, which has to be installed manually. Everything else is just copy paste
- kzali
07 Sep 2024 07:25 #309544
by kzali
Agreed just a pull and there you go. Thanks.I would prefer the route described above,
- meister
10 Sep 2024 15:29 - 10 Sep 2024 15:30 #309851
by meister
the quick gowin install way without login
mkdir -p /opt/gowin
cd /opt/gowin
wget "https://cdn.gowinsemi.com.cn/Gowin_V1.9.9.03_Education_linux.tar.gz"
tar xzvpf Gowin_V1.9.9.03_Education_linux.tar.gz
rm -rf Gowin_V1.9.9.03_Education_linux.tar.gz
export PATH=$PATH:/opt/gowin/IDE/bin/
Last edit: 10 Sep 2024 15:30 by meister.
- Dima
13 Jan 2025 01:57 - 13 Jan 2025 01:58 #318844
by Dima
Replied by Dima on topic Riocore setup from scratch for dummies
Hi. I am just learning LinuxCNC. I followed all the instructions, but encountered the following problem: after entering `PYTHONPATH=. bin/rio-setup riocore/configs/Tangoboard/config.json`, I get the message "ACCESS DENIED". When I add `sudo` before the command, I get the message "COMMAND NOT FOUND". What should I do? I installed the latest version of LinuxCNC today, and there were no errors in the previous steps.
P.S. I apologize, I am not very good at English and I am using a translator.
Last edit: 13 Jan 2025 01:58 by Dima.
- epineh
20 Jan 2025 09:23 #319446
by epineh
Replied by epineh on topic Riocore setup from scratch for dummies
Hi Dima, even though I wrote this "how to" I would recommend using the docker method of installing :
github.com/multigcs/riocore/blob/main/DOCKER.md
It makes life a lot easier, just use the linuxcnc debian live install operating system, sounds like you already have it installed. It should work without issue, I have tried using Ubuntu and Kali linux but they have problems running the docker setup.
Russell.
Russell.
Time to create page: 0.107 seconds
