Method for Zeroing a "c" axis
- Thank you received: 4648
07 Sep 2024 17:36 #309593
Replied by andypugh on topic Method for Zeroing a "c" axis
There may be an issue with 32-bit counters. Many of the drivers internally store 32-bit HAL pins as 64 bit long int, but not all and I think that some Mesa drivers may be amongst them.
I might change all HAL pins to 64-bit for 2.10 (as I don't see any point in having both 32 bit and 64 bit at the same time). I think that can be done transparently in most cases.
- M4MazakUser
- Thank you received: 7
23 Sep 2024 09:46 #310633
by M4MazakUser
Replied by M4MazakUser on topic Method for Zeroing a "c" axis
So the g10 l20 method looks to be the go, I'll probably try it tomorrow. The idea is m106 --> brake off/ engage c axis/ read spindle position, convert it to integer, subtract the integer from the spindle position, then multiply the remainder (0.***) with 360, g10 l20 to set the current c drive position to the spindle position. / if doing a drilling or milling fixed movement execute an m05 to turn on the spindle brake. Then m106 to release the brake re-assert spindle position etc.
Doing milling on c axis is doing my head in, Im trying to write a cycle to do it, but tool radius compensation to do a square is complex and the calculations for the angular related spindle position in regards to the x position is quite a lot of trig.
- M4MazakUser
23 Sep 2024 10:06 #310634
by M4MazakUser
Geuss there's no way to get polar coordinates working on the x/c axis.
- spumco
- Thank you received: 896
23 Sep 2024 12:40 #310643
by spumco
I'm aware of two working configurations; there may be more buried in some obscure forum post or github page.
First is from user NoJo.
forum.linuxcnc.org/10-advanced-configura...oling?start=0#225787
I started playing around with incorporating his configuration in my XZC lathe earlier this year, but I've been sidetracked and don't have anything concrete. I seem to recall a problem (for the rest of us) with NoJo's kinematic module is that he hard-coded a tool offset in the component rather than using a parameter or value based on tool table data plus X-axis position. It's a little hazy now.
The second is more recent, and is from Franco (@fsabbatini).
forum.linuxcnc.org/show-your-stuff/53476...rical-mapping#307444
This is for cylindrical mapping - i.e. tool oriented radially as with cross-drilling - but I suspect it could be edited for axial live tools and polar interpolation. I have not looked closely at Franco's scheme - as usual I get sidetracked off projects.
When I finish my mill in the next few weeks (months) I'll be getting back to my lathe project and polar interp will be near the top of the to-do list. If you get something working (or not) please post up. I will do the same when I get back to it and make some progress.
If we (and a few other users who have chimed in in the past year or so) can create a very universal kinematics module, we might be able to get it incorporated in to LCNC mainline code. There are a few lathe-related features which seem to be a recurring "how do I" forum topic that nonetheless aren't on any developer's list of things to add to mainline LCNC:
Replied by spumco on topic Method for Zeroing a "c" axis
The way to do it is by switching kinematics on the fly using switchkins. But LCNC has no 'built-in' polar interpolation or an example in the sims.Geuss there's no way to get polar coordinates working on the x/c axis.
- C-axis/spindle management (one or two motors, one or two encoders)
- I know this one is fiddly as it's extremely dependent on the user's actual hardware choices
- Rotary axis look-ahead
- Spindle homing
- Polar interpolation
- Cylindrical interpolation
- GUI handling of multiple tool orientations
- Automatic backplot adjustments triggered by any of the above
The following user(s) said Thank You: tommylight, besriworld
Time to create page: 1.641 seconds
