Debian 12 Bookworm Update problem
06 Sep 2024 17:04 - 06 Sep 2024 17:07 #309512 by RLA
Hi...I have no experience with linux but downloaded Debian 12 Bookworm ISO...installed..no internet...have connection now but get the following when I try...I also was not able to run mesa configuration tool...clock is also wrong...related??
Thanks for any help!!
 sudo apt update
Ign:1 cdrom://[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240721-21:05] bookworm InRelease
Err:2 cdrom://[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240721-21:05] bookworm Release
  Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Hit:3 www.linuxcnc.org bookworm InRelease
Get:5 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease [1,575 B]
Err:5 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
  The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org>
Hit:4 repository.qtpyvcp.com/apt develop InRelease
Reading package lists... Done
E: The repository 'cdrom://[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240721-21:05] bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
Last edit: 06 Sep 2024 17:07 by RLA.
06 Sep 2024 17:27 #309513 by tommylight
Replied by tommylight on topic Debian 12 Bookworm Update problem
sudo apt update
then
sudo apt upgrade
The following user(s) said Thank You: RLA
06 Sep 2024 17:44 #309516 by RLA
Replied by RLA on topic Debian 12 Bookworm Update problem
Hi...got the same result as posted above...below is pasted result...do I need to reinsert usb that had ISO?
sudo apt update
ra@debian:~$ sudo apt update
[sudo] password for ra:
Hit:4 www.linuxcnc.org bookworm InRelease
Hit:3 repository.qtpyvcp.com/apt develop InRelease
ra@debian:~$ sudo apt upgrade
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remo
07 Sep 2024 10:41 #309560 by andypugh
Replied by andypugh on topic Debian 12 Bookworm Update problem
Ignore the Etherlab errors, that's out of our (and your) control.
22 Sep 2024 13:42 - 22 Sep 2024 13:44 #310600 by juergen-home
Replied by juergen-home on topic Debian 12 Bookworm Update problem
I had the same problem today (After no Internet at the time of install the other day).
It was not possible to install the usbutils and I found out there was no mirror for "debian bookworm main" so I kicked out the open suse miror and added the debian mirror with synaptic.
Last edit: 22 Sep 2024 13:44 by juergen-home.
23 Sep 2024 13:26 #310646 by muekno
Replied by muekno on topic Debian 12 Bookworm Update problem
similar Problem here, runnig Debian since years never hat a problem till now.
Cannot update
Last Update on september 1st did work
need solution
05 Dec 2024 20:11 #316038 by vibram
Replied by vibram on topic Debian 12 Bookworm Update problem
Hello
I have exactly the same issue on a brand new install with the iso from linuxcnc download section. I'm. Not able to update at all. Any idea?
Thank you
05 Dec 2024 20:23 #316039 by tommylight
What is the result of
sudo apt update
And
sudo apt upgrade
05 Dec 2024 20:24 - 05 Dec 2024 20:45 #316040 by Grotius
Replied by Grotius on topic Debian 12 Bookworm Update problem
apt sources list is set on local cd. This is my suggestion.
edit the sources.list to update from internet sources.
~/etc/apt/sources.list
Easy to use in terminal is :
sudo thunar
# See https://wiki.debian.org/SourcesList for more information.
deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
deb-src http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware
deb http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
deb-src http://deb.debian.org/debian bookworm-updates main contrib non-free non-free-firmware
deb http://security.debian.org/debian-security/ bookworm-security main contrib non-free non-free-firmware
deb-src http://security.debian.org/debian-security/ bookworm-security main contrib non-free non-free-firmware
sudo apt get update // Fetch the sources list.
Then try it again.
Last edit: 05 Dec 2024 20:45 by Grotius. Reason: improved ansfer
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
05 Dec 2024 21:46 #316052 by rodw
Replied by rodw on topic Debian 12 Bookworm Update problem
Typically this happens if you try to install Linuxcnc without an internet connection.
Always connect to the internet when installing the linuxcnc ISO
Time to create page: 0.228 seconds
