mint 22 -- rip-install work perfect --- but not possible definitive install
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Oct 2024 16:30 - 08 Oct 2024 13:45 #311531 by bkt
in my so rip-install of master running well ... but need to install it. Im on Linux Mint22 kernel 6.10.2-rt14
So I try to use
[code]> cd linuxcnc-dev/debian
> ./configure uspace
> cd ..
[code]> dpkg-buildpackage -b -uc
for create deb package .... or try to use
[code]cd linuxcnc-dev/src
./autogen.sh
./configure --with-realtime=uspace --enable-non-distributable=yes
$ make -j4
$ sudo make setuid
cd ..
. ./scripts/rip-environment
sudo make install
but receive error
[code]make: *** No rule to make target 'install-kernel-dep', needed by 'install-software'.  Stop.
at make step ..... or other error at [code]> dpkg-buildpackage -b -uc step ..... so nothing Lcnc install.
my suspicius is need to indicate kernel header because not a normal debian 12/13 SO.
so these command can be right?
./configure --with-realtime=uspace --enable-non-distributable=yes ....... kernel-version (linux-headers-6.10.2-rt14 ... for example) ....
but strange ..... i search on synaptic these kernel 6.10.2-rt14 ... but not  find on list ... is normal? because not remember if normal or not.
but uname -r show me 6.10.2-rt14 ... so think must be present on synaptic as installed headers right?
[/code][/code][/code][/code][/code]
Last edit: 08 Oct 2024 13:45 by bkt.
  • bkt
  • Platinum Member
  • Platinum Member
08 Oct 2024 14:40 - 08 Oct 2024 15:24 #311604 by bkt
I reply by my .... problem was new Glibc and  _FORTIFY_SOURCE ..... see little tutorial just write here: forum.linuxcnc.org/9-installing-linuxcnc...ll-over-linuxmint-22
Last edit: 08 Oct 2024 15:24 by bkt.
Time to create page: 0.231 seconds
