Adding GUI file to bootable pend drive is this possible
12 Oct 2024 19:39 #311908 by jonsar
 hi  i have a good working 2.5.3 linuxcnc i have made a bootable with the latest  2.9.3 it moves my cnc now i would like to add the GUI config to the bootable drive to have a play  i do have more latencey on the 2.9.3 than the 2.5.3 but still at the acceptable level so Im realy trying to gauge if its worth while up grading thanks for all your help
  • Moderator
  • Moderator
12 Oct 2024 19:57 #311913 by tommylight
What GUI?
Every GUI that existed in 2.5 should exist in 2.9 and much more....
If you want to have stuff saved to USB, google "debian 12 persistence usb"
12 Oct 2024 21:05 #311916 by jonsar
hi
may be my termanoligy is incorrect the man that set up my cnc said
"You can update linuxcnc and then use linuxcnc axis gui as my gui on those machines are for older python and newer lcnc uses newer python. I have upgraded my gui and can send you if you want. Maybe upgrade to lcnc 2.9.2"
so i just want my dimenions and soft stops in the new version
12 Oct 2024 21:41 #311918 by jonsar
i googled it and read through 4 or 5 posts just gave me a head ache i get i need to add a partiton but i dont really get how is there a plain english explation
12 Oct 2024 21:55 #311919 by jonsar
hi i understand linux and linuxcnc are program languages and i am at the start of the learning process but it is a head f!@k
where can i go to get a better basic understanding of how it all works in a very basic english so i can move on thanks
  • Moderator
  • Moderator
13 Oct 2024 06:51 #311951 by tommylight
If i understand this correctly, you need the configuration folder, not the GUI, so that is usually in the /home/user_name/emc2/configs for 2.5 version, just save that to a usb.
Then you can start that config by right clicking on the .ini file and choosing 'open with' then typing 'linuxcnc' and OK.
13 Oct 2024 19:07 #312014 by jonsar
hi i have the new config file just need to know how to insert it to my bootable pen drive before i commit to updating the hard drive thanks
  • Moderator
  • Moderator
13 Oct 2024 20:03 #312018 by tommylight
That has to be done after the installation.
Or use 2 USB sticks, one with LinuxCNC ISO and one with the config folder, but this is for testing only, to make sure you saved the correct configuration.
14 Oct 2024 12:19 #312078 by cakeslob
What GUI?
mini and keystick were axed after 2.7
  • Moderator
  • Moderator
14 Oct 2024 12:57 #312083 by tommylight
What GUI?
I was not aware of that, thank you very much.
Time to create page: 0.421 seconds
