Linux is an RTOS NOW
- Benb
- Thank you received: 61
14 Oct 2024 17:33 #312103
by Benb
Linux is an RTOS NOW was created by Benb
Linux is now RTOS. It took 20 years but they finally succeeded !
www.phoronix.com/news/Linux-6.12-Does-Real-Time
- Thank you received: 7504
14 Oct 2024 17:40 #312104
Replied by tommylight on topic Linux is an RTOS NOW
Good news, thank you.
I did try the 6.11 with RT on this PC and it failed to load, need more time to test on more hardware, soon!
- Thank you received: 4154
17 Oct 2024 06:28 #312360
Replied by rodw on topic Linux is an RTOS NOW
You still need to set the PREEMPT_RT flag and build the Linux kernel. its not RT by default.Linux is now RTOS. It took 20 years but they finally succeeded !
17 Oct 2024 09:00 #312381
6.11 shows SMP PREEMPT_DYNAMIC out of the box, did not test LinuxCNC yet.
- Thank you received: 2177
17 Oct 2024 09:48 #312395
Replied by Aciera on topic Linux is an RTOS NOW
Preempt-dynamic is not preempt-rt though:
stackoverflow.com/questions/77564174/is-...-dynamic-set-on-full
17 Oct 2024 21:54 #312463
PREEMPT_RT Real time OS is supported natively from Kernel 6.12 and on so not 6.11 (which will require applying the RT patches) before setting the Preempt RT switch and building.6.11 shows SMP PREEMPT_DYNAMIC out of the box, did not test LinuxCNC yet.
The following user(s) said Thank You: xu
- NTULINUX
- Thank you received: 84
08 Nov 2024 20:25 - 16 Nov 2024 20:39 #314105
by NTULINUX
Replied by NTULINUX on topic Linux is an RTOS NOW
I'll be hosting a heavily optimized AMD64 Gentoo build for LinuxCNC and I'll be updating my interactive Gentoo installer too, it'll have the 6.12 PREEMPT_RT kernel, XFCE 4.20 pre-release and LXQt 2.1.
Installer works very well, removes all the hassle from building sources, works with LinuxCNC out of the box (just have to emerge it) and the installer works faster than Ubuntu and Debian installers. It's just out-of-date at the moment.
edit: Currently having serious issues with lxqt-panel (the fricken task bar) so it may just have XFCE instead.
edit2: Problems solved, LXQt will be available in this build too.
Last edit: 16 Nov 2024 20:39 by NTULINUX. Reason: LXQt might not be possible at the moment
The following user(s) said Thank You: tommylight, onceloved, xu
Time to create page: 0.452 seconds
