recent Update makes LinuxCNC defect
- Deje63
- Topic Author
2 years 5 days ago - 2 years 5 days ago #313443
by Deje63
recent Update makes LinuxCNC defect was created by Deje63
I want to switch from normal HD to ssd. There is no other change in Hardware, neither the PC nor the CNC machinery.
It works over parallel port and M542 driver as for years. The mill itself is a DIY 3 axis machine.
I downloaded the current Debian Amd64 2.9.3 PREEMPT-RT Hybrid ISO and installed it.
Also I did create a new config for Gmoccapy/machine, my current config is just to old to get converted (got a lot of errors). Anyway, the installation went OK and the machine is working as expected.
Now I did an upgrade
which in general also went OK. Paranoid reboot and start LinuxCNC. Now I got the issue all but Y-axis moving. The motor gives some noise but not really moving. Whatever I tried, changing/relaxing timings and so on, it did not start to work correctly. X- and Z- still working.
I did search but did not found similar issue messages.
The question is, may someone had an easy fix or should I just reinstall and avoid upgrade for some time?
Thanks for reading,
DeJe
apt update
apt upgrade
Thanks for reading,
DeJe
Last edit: 2 years 5 days ago by Deje63. Reason: wrong driver
- Thank you received: 426
2 years 4 days ago #313464
Replied by Cant do this anymore bye all on topic recent Update makes LinuxCNC defect
Please supply config files.
- Deje63
- Topic Author
2 years 4 days ago #313497
by Deje63
Replied by Deje63 on topic recent Update makes LinuxCNC defect
Good news.
I got it working in changing the control pins for Y-axis (from 3/16 original Y-axis, to 5/6 original A-axis) on the parallel port.
But it is really weird why 2.9.3 is not working in the original Y-axis config but the old config still works with this config.
Attached the original config. As said I just swapped 2 pins around...
btw. the old version I was running was 2.7.0 Pre, I did build them myself from sources.
Thanks a lot,
DeJe
Thanks a lot,
DeJe
2 years 3 days ago #313516
Hmmm that's a weird one.
At a guess it could be a local hardware issue that manifested itself when you made the changes. As this is a guess I could be wrong.
Many many moons ago I had a PSU fail when I did an upgrade from Win2k to WinXP. I think the gremlins that lived in the PSU thought it would be funny to push the fail button just after I did the upgrade. They seem to like Linux more.
Time to create page: 0.049 seconds
