Installing LinuxCNC on Ubuntu 24.04 LTS is not possible.
1 year 11 months ago #314942 by tommylight
sudo apt update
sudo apt install linuxcnc-uspace
No idea if it works on Ubuntu 24 but it did on 22 or 23.
The above also works on Linux Mint Debian Edition 6, should also work on Debian 13.
ASUS ROG Crosshair VIII Impact - AMD X570
1 year 7 months ago #324737 by 5G-antry
for your information, I had the same issue.
I am currently debugging and check if it will work. I can then update you :)
Could also not compile it myself due to dependencies issues.
1 year 7 months ago #324773 by unknown
I find Ubuntu great for a server, much easier to add software to than Slackware, now that was dependency hell, sometime you'd spend all day installing\replacing packages from source just to install one package. Even if the packages were available you'd have to work out what else to add.
Either Mint or Debian for desktop. Used to use some of the first version of Puppy Linux, prior to it having wifi and helping to get that going.
Time to create page: 0.134 seconds
