Installation after new computer
29 Nov 2024 16:20 #315591 by Lik2waterski
Installation after new computer was created by Lik2waterski
Hello, my router table is currently running Linux Mint 19.3 Tricia and Linuxcnc  2.8.0.  The table is wired to Mesa cards 7i76-7i92M.
I am going to try to hook up the tool changer using the Carousel config.  I decided it would be a good time to install my new computer
prior to working on the tool changer. On my computer I just installed Linux Mint 22 _wilma. Can someone help me choose the right version of linuxcnc to install so that I can copy my configs over and (hopefully) work seamlessly?
Thanks for any help,
Travis
29 Nov 2024 22:15 #315601 by PCW
Replied by PCW on topic Installation after new computer
I would update to the latest normal release (2.9.3)
I don't think there are any major hal/ini file changes
between 2.8 and 2.9
The following user(s) said Thank You: Lik2waterski
  • Moderator
  • Moderator
29 Nov 2024 23:55 #315607 by tommylight
Replied by tommylight on topic Installation after new computer
On Mint 22 you will have to compile LinuxCNC from sources, otherwise it does not work.
Linux Mint Debian Edition 6 works, install reboot, then in a terminal
sudo apt update
sudo apt install linuxcnc-uspace
Time to create page: 0.083 seconds
