Instlal error : Failed to create a file system
- garthnoakes
- Thank you received: 9
23 Dec 2024 13:09 #317217
by garthnoakes
Instlal error : Failed to create a file system was created by garthnoakes
I get this error using the same install steps I have successfully used on other PCs. The message is "The efi file system creation in partition ## of SCSI1 (0,0,0) (sda) failed.
I'm booting off a DVD, I can run the live image from it with no problems
- Thank you received: 4154
23 Dec 2024 13:22 #317218
Replied by rodw on topic Instlal error : Failed to create a file system
Try disabling secure boot/EFI in your BIOS and start again
Time to create page: 0.097 seconds
