Raspi5 + VH229 no HDMI0 audio
06 Jan 2025 05:58 #318193 by Martin.L
Raspi5 + VH229 no HDMI0 audio was created by Martin.L
Hi Guys new here, I have installed the Ethercat image following the guide from RodW on a Raspi5 + VH229. All worked out but a monitor on HDMI0 don't give me audio out. I can see graphically the audio mixer gives me a dummy output and if I select hardware outputs there are no one. Toughts?
  • Platinum Member
  • Platinum Member
06 Jan 2025 06:22 #318197 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Raspi5 + VH229 no HDMI0 audio
You may have to look through the config.txt and see if the audio is enabled. The file is not in the same place as the Raspbian OS, still somewhere in a directory under boot. The RPi docs regarding config.txt are still valid as as source of info.
Generally I disable audio on my cnc machines.
06 Jan 2025 09:07 - 06 Jan 2025 09:08 #318203 by Martin.L
Replied by Martin.L on topic Raspi5 + VH229 no HDMI0 audio
Thanks for your reply,
Here is my config, audio seems on
Warning: Spoiler!
Last edit: 06 Jan 2025 09:08 by Martin.L.
07 Jan 2025 17:39 #318314 by Martin.L
Hi, still I can't figure out whats the issue, sigh
Time to create page: 0.181 seconds
