bookworm/master-uspace/binary-amd64
08 Jan 2025 13:40 - 09 Jan 2025 08:35 #318404 by La Pendule
bookworm/master-uspace/binary-amd64 was created by La Pendule
Hi all,
Just one question: On buildbot2.highlab the bookworm/master-uspace/binary-amd64 has not been updated since 2024 October 24th.
The source is now version 2.10.0-pre0-3979-gbc86e90f8b from  January 7th. 2025
LinuxCNC can so not more be updated via synaptic or apt install.
Is there a chance that the binary-amd64 will be updated soon ?
Thanks a lot for help
Regards
PW
Update 2025.01.09:
This morning the
binary-amd64 was updated. Thanks a lot to all contributors.
PW
Last edit: 09 Jan 2025 08:35 by La Pendule. Reason: Update
12 Jan 2025 17:13 #318799 by andypugh
Replied by andypugh on topic bookworm/master-uspace/binary-amd64
The builder in question was out of disk space. This has been fixed.
12 Jan 2025 19:34 #318817 by La Pendule
Replied by La Pendule on topic bookworm/master-uspace/binary-amd64
Yes I saw !
Thanks a lot.
Kind regards
Philippe
13 Jan 2025 11:54 #318864 by RNJFAB
Replied by RNJFAB on topic bookworm/master-uspace/binary-amd64
On Synaptic Package Manager, 2.9.0 is the latest version.
Is there another way to upgrade to version 2.10?
14 Jan 2025 01:14 #318913 by rodw
Replied by rodw on topic bookworm/master-uspace/binary-amd64
This is a bit tricky if you are using the 2.9 download. the official Linuxcnc repo does not contain 2.10
You would need to edit linuxcnc-uspace.list in one of the /etc/apt folders to use the buildbot2 settings described here
buildbot2.highlab.com/
Otherwise download a deb file from there and install it.
Time to create page: 0.087 seconds
