New PC, Same Mesa 7i96s - No Board Found
- notJamesLee
- Thank you received: 5
23 Jan 2025 17:03 - 23 Jan 2025 17:07 #319738
by notJamesLee
New PC, Same Mesa 7i96s - No Board Found was created by notJamesLee
Hi Friends,
While i was working on my machine the RP4 and touchscreen i had it mounted to took a tumble and unfortunately the screen will not be returning. I took this as an opportunity to upgrade from a RP4 to one of those mini computers. All went well from the install perspective, there were no issues in the live environment or from the latency test. I moved forward with an install on the main disk and just finished going through the pncconf wizard with the same settings i had working with the RP4 and i get an error that looks like at real-time error. (pasted below)
I downloaded mesa flash to the new machine and am not able to ping it at 10.10.10.10 and ill post the output of ip -a on the new machine with the mesa (machine) powered on.
note: this output from ip a is the same with the machine off or on
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11) ./Cutter.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth ./Cutter.hal:9: /usr/bin/rtapi_app exited without becoming ready ./Cutter.hal:9: insmod for hm2_eth failed, returned -1 6432I downloaded mesa flash to the new machine and am not able to ping it at 10.10.10.10 and ill post the output of ip -a on the new machine with the mesa (machine) powered on.
james@CNCPC:~$ ip a 1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host noprefixroute valid_lft forever preferred_lft forever 2: enp2s0: mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether 84:47:09:43:53:ec brd ff:ff:ff:ff:ff:ff inet6 fe80::3f75:d82e:1e8:6d86/64 scope link noprefixroute valid_lft forever preferred_lft forever 3: wlp0s12f0: mtu 1500 qdisc noqueue state UP group default qlen 1000 link/ether 2c:7b:a0:45:3c:b0 brd ff:ff:ff:ff:ff:ff inet 192.168.0.30/24 brd 192.168.0.255 scope global dynamic noprefixroute wlp0s12f0 valid_lft 83688sec preferred_lft 83688sec inet6 fe80::2e7b:a0ff:fe45:3cb0/64 scope link noprefixroute valid_lft forever preferred_lft forevernote: this output from ip a is the same with the machine off or on
Last edit: 23 Jan 2025 17:07 by notJamesLee. Reason: adding error and cmd output
- Thank you received: 7504
23 Jan 2025 17:21 #319739
Replied by tommylight on topic New PC, Same Mesa 7i96s - No Board Found
Networking is not set up
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
The following user(s) said Thank You: notJamesLee
- notJamesLee
23 Jan 2025 20:40 #319742
by notJamesLee
Replied by notJamesLee on topic New PC, Same Mesa 7i96s - No Board Found
That worked thank you!
I am now getting a "joint 2 on limit switch" error when i try to jog the machine on start up. The only other thing that changes is i went from gmocappy to axis (since i no longer have a touch screen).
I went to hal show and tested all three (still waiting on the fourth) limit switches and both estops do what they should.
Should i undo the "-not" ? If that was the case shouldn't it be all the joints?
- Thank you received: 5336
24 Jan 2025 09:15 #319758
Replied by PCW on topic New PC, Same Mesa 7i96s - No Board Found
In hal show, the limit switch pins should show false (red) when not activated and
true (yellow) when activated, is this the case?
- notJamesLee
03 Feb 2025 10:50 #320510
by notJamesLee
Hi Friends,
Sorry for the delay in getting and update posted. I got the tandem limit switch wired up and all of the pins inverted so now i am getting a red state at idle but when the limit switch or estop is depressed it turns yellow. So all my estop and limit pins seem to be working as expected.
I think this topic is solved. I have a litany of other issues that if i need novel help ill create a new topic. I appreciate your help. Slowly but surely we're going to get a working machine.
Time to create page: 0.190 seconds
