- Thank you received: 6
I found the perfect reply: forum.linuxcnc.org/9-installing-linuxcnc...s-linuxcnc-vm#319841I beg to disagree.
Running Linuxcnc in a VM will be no different if it's arm based or x86 based.
In actual fact running Linuxcnc on real a x86 (amd64) platform or a real ARM (ie RPi4 or 5) platform is the same. Apart from hardware that is specific to each platform.
Linuxcnc can not be used for realtime inside a VM. Simualtion is fine.
Now, anything to do with Parallels isn't a Linuxcnc issue. Maybe if you tried a Mac forum and asked politely, someone may want to perform this task for you. Like "Can someone with an Intel Mac create a x86 Linuxcnc VM for me to use on my Arm based Mac." That would have made life easier if you have had just asked that to begin with.
You're wrong.Now from my understanding, correct me if I'm wrong, you would like to run Linuxcnc in a Parallels VM.
Obtain a Parallels VM of LinuxCNC created on an Intel Mac.What is your are trying to do ?
