- Thank you received: 7491
Its great that you acknowldge that responsibility for the receiving of a message rests with the sender!I understand that I cannot demand better answers; I have no control over how people respond. I have control over:
1) How I ask questions;
2) Where I ask questions.
I need to get better at both.
Both links I included explain in explicit detail why I need someone with an Intel Mac and Parallels to create a VM on that hardware for me load into my Apple Silicon Mac. It was, and still is, all that I need to try out x86 emulation in Parallels 20.2.This time you can blame it on me as if i recall correctly, Parallels is the software running on Apple hardware and makes it possible to run other operating systems in it, in short running virtual machines.
If that is correct, then all my answers are on point, it should run any ISO without making images on other hardware, that is the whole point of it.
Then again, it is Apple, so maybe only runs ARM stuff?
What you're suggesting has absolutely nothing to do with what I asked for.As you'll only be able to run in simulation mode and you just want to get familar with Linuxcnc an arm install will be fine.
After doing a quick read I'd research the following:
Is Debian Bookworm able to be run. The kernel versions and X server versions seem to be limited.
Is the Kernel version that is on the Linuxcnc iso compatitable ?
