Raspberry pi 5 su password
- Stephen Boutwell
06 Feb 2025 23:16 #320885
by Stephen Boutwell
Raspberry pi 5 su password was created by Stephen Boutwell
Good evening, I downloaded and burned the latest raspberry pi 5 image and have run into a couple of problems. The user "cnc" password "cnc" lacks root access and only has read access to the etc file. Is there a SU password for this latest image. I need to make some changes to the etc /network files as there is no apparent network manager showing in the available applications. Thanks!
- unknown
- Thank you received: 323
07 Feb 2025 01:14 #320889
by unknown
Replied by unknown on topic Raspberry pi 5 su password
Just use.
If you want you can installthen reboot
sudoIf you want you can install
sudo apt install network-manager-gnomePlease Log in or Create an account to join the conversation.
- Thank you received: 4154
07 Feb 2025 02:46 #320892
Replied by rodw on topic Raspberry pi 5 su password
None of the Linuxcnc images and ISOs install a root user so sudo is required
Sometimes I do: sudo su
which gives you a root access (you will see the prompt change) untill you type: exit
Time to create page: 0.348 seconds
