Devuan, RPi5 & Linuxcnc Image
25 Feb 2025 01:52 #322549 by unknown
Devuan, RPi5 & Linuxcnc Image was created by unknown
As per title, is this something anyone would be interested, not meant as a replacement for the official image. If your new to Linuxcnc I would recommend the images on the download page.
Main reason for experimenting with this image:
Sysvinit rather than systemd, some prefer this option for personal reasons.
I really like the Devuan Project's CoC.....I know this subject can be quite polarizing for some. Yes I know it is "based" on Debian.
Just wanted to have a look at Devuan, so 2 birds with one stone sort of thing.
Out of the box no zramswap.service issue....may not mean much, but there has been a bit of discussion on this front.
Choice, whether this is good or bad or confusing.
I included network-manager & network-manager-gnome for easier network setup. There is some debate regarding the affect on latency, so there is some debate around that. Also some nice stuff such as xarchiver & thunar plugin (create & expand archives via right clicking in thunar file manager), evince (pdf reader) so for those that are curious can read the Linuxcnc docs.
As per the bookworm images menu-config is used to set locales & such and same username:password to login, cnc:cnc.
Have Fun
Rob
The following user(s) said Thank You: tommylight, behai
07 Mar 2025 19:50 #323457 by andypugh
Replied by andypugh on topic Devuan, RPi5 & Linuxcnc Image
Which libgpiod?
08 Mar 2025 04:59 #323493 by unknown
Replied by unknown on topic Devuan, RPi5 & Linuxcnc Image
Hi Andy,
Output of dpkg --list | grep libgpiod
ii  libgpiod2:arm64                      1.6.3-1+b3
I did a quick load of hal_gpio, didn't run a config, but it loads ok.
spix works fine even with my cobbled together 7c81 clone
Linuxcnc complains about /usr/bin/kill not being there but it's under /bin/kill which might have to do with debian having /bin /sbin & /lib being links to /usr/bin /usr/sbin & /usr/lib/ and Devuan not taking that road.
I'm actually Devuan to make this post.
I've only made a RPi5 image ATM but would you like an RPi4 image made ?
02 Apr 2025 13:37 #325518 by andypugh
That's something that is meant to have changed in Debian too, in fact LinuxCNC is being "told off" about it:
github.com/LinuxCNC/linuxcnc/pull/3388
Time to create page: 0.105 seconds
