Ethernet Settings for Raspi4
- Nathan40
05 Mar 2025 06:42 #323257
by Nathan40
Ethernet Settings for Raspi4 was created by Nathan40
Hi All,
I am unable to connect 7i95t on raspi4 with the below settings. Ping is not sending any data. Please suggest as what I am doing wrong!
# Ethernet
allow-hotplug eth0
iface eth0 inet dhcp
address 10.10.10.1
netmask 255.0.0.0
gateway 10.10.10.1
dns-nameservers 8.8.8.8 8.8.4.4
# Ethernet
allow-hotplug eth0
address 10.10.10.1
netmask 255.0.0.0
gateway 10.10.10.1
- Thank you received: 7504
05 Mar 2025 07:10 #323261
Replied by tommylight on topic Ethernet Settings for Raspi4
What does
ip a
in a terminal return?
ip a
- unknown
- Thank you received: 323
05 Mar 2025 08:21 #323268
by unknown
Replied by unknown on topic Ethernet Settings for Raspi4
The issue is that interface is setup for both dhcp and a static address.
I'd do a write up about how to setup an interface but for 2 reasons, it would get lost and ignored, and this kind of thing has been discussed far too many times to recall.
I think people have lost the art of being able to search.
- unknown
05 Mar 2025 08:24 #323269
by unknown
Read this page, not just the chapter in the link.
wiki.debian.org/NetworkConfiguration#Con...e_interface_manually
05 Mar 2025 09:15 #323277
Yeaaa man, sorry i missed that.The issue is that interface is setup for both dhcp and a static address.
- Nathan40
05 Mar 2025 10:44 #323288
by Nathan40
Replied by Nathan40 on topic Ethernet Settings for Raspi4
Thanks for your reply! If possible can you share exact settings so that noobs like us can know and get this 7i95t up and running. Any help will be highly appreciated.
05 Mar 2025 11:19 #323292
We can not give you exact settings as you did not reply to our questions, so go back, read and reply.
- Thank you received: 5336
05 Mar 2025 11:40 - 05 Mar 2025 11:42 #323294
Replied by PCW on topic Ethernet Settings for Raspi4
As others have mentioned, you definitely do not want DHCP and you do
need to set a static address.
You might try this:
auto eth0
iface eth0 inet static
address 10.10.10.100
netmask 255.255.255.0
DO NOT set a gateway or nameservers
You might try this:
auto eth0
Last edit: 05 Mar 2025 11:42 by PCW.
The following user(s) said Thank You: unknown
- unknown
05 Mar 2025 19:27 #323323
by unknown
Thanks Pete
I've added your post to the RPi sticky in the Installing Linuxcnc Section.
- Nathan40
06 Mar 2025 20:57 #323400
by Nathan40
Thanks PCW for your help! Cheers.
Time to create page: 0.919 seconds
