QTplasmac Configs do not open after converting to master debs on buildbot2
- Thank you received: 4089
22 Mar 2025 05:27 - 22 Mar 2025 05:34 #324518
QTplasmac Configs do not open after converting to master debs on buildbot2 was created by rodw
I adjusted the apt settings so Debian gets the buildbot2 deb file for LinuxCNC V 2.10.
The upgrade of linuxcnc was sucessful.
When I open a config from the consiole, a window appears that says
Updated to V2.10-001.017, Due to Configuration a Restart is required
I open the config and I get the same error
I reboot and I get the same error
I though tthen to check the ini fil to make sure it is not read only. It was so I updated the permisssions to write to it.
But I still can't open any config,
How do I resolve this?
Last edit: 22 Mar 2025 05:34 by rodw.
22 Mar 2025 05:35 #324519
Replied by rodw on topic QTplasmac Configs do not open after converting to master debs on buildbot2
Ooops, this is QTplasmac specific and that is jut opening a Sim already on my PC. But I do need to edit a live sim
- Thank you received: 7419
22 Mar 2025 11:54 #324536
Replied by tommylight on topic QTplasmac Configs do not open after converting to master debs on buildbot2
Moved to "PlasmaC" section.
Thank you.
Thank you.
