Help with git - SOLVED
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 May 2025 19:10 - 09 May 2025 20:03 #328097 by zz912
Help with git - SOLVED was created by zz912
Hello,
I am learning git. I cloned data from Github. I compiled it with branches copied from master branche.
I made my first Pull Request with git.
github.com/LinuxCNC/linuxcnc/pull/3434
I celebrated. Everything was fantastic.
Then I needed work with 2.9 branche.
I checked out it:
zdenek@cnc:~/linuxcnc/linuxcnc-zz912$ git checkout 2.9
branch '2.9' set up to track 'origin/2.9'.
Switched to a new branch '2.9'
zdenek@cnc:~/linuxcnc/linuxcnc-zz912$ git branch
* 2.9
  master
  pnc-aut-g43
Then I made:
zdenek@cnc:~/linuxcnc/linuxcnc-zz912/src$ ./autogen.sh
zdenek@cnc:~/linuxcnc/linuxcnc-zz912/src$ ./configure --with-realtime=uspace
zdenek@cnc:~/linuxcnc/linuxcnc-zz912/src$ make -B
Making halcompile manpage constant.9
Making halcompile manpage conv_bit_float.9
Making halcompile manpage conv_bit_s32.9
Making halcompile manpage conv_bit_s64.9
hal/components/conv_bit_s64.comp:3:9: Trying to find one of TYPE
>  pin out s64 out;
while parsing Declaration():
>  pin out s64 out;
while parsing File():
>  pin out s64 out;
make: *** [hal/components/Submakefile:35: ../docs/man/man9/conv_bit_s64.9] Chyba 1
I must do something wrong, because I tried compile branche 2.9 downloaded from Github in zip file and It worked.
I tried git clean and it did not help.
How should I work with different branches with git?
Last edit: 09 May 2025 20:03 by zz912.
09 May 2025 19:44 #328100 by PCW
Replied by PCW on topic Help with git
I have seen that with master and 2.9
Did you
make clean
after changing branches?
The following user(s) said Thank You: zz912
  • zz912
  • Platinum Member
  • Platinum Member
09 May 2025 19:46 #328101 by zz912
Replied by zz912 on topic Help with git
Yes, I did. But it did not help.
  • zz912
  • Platinum Member
  • Platinum Member
09 May 2025 19:49 #328102 by zz912
Sorry, I made "git clean", I will try "make clean".
  • zz912
  • Platinum Member
  • Platinum Member
09 May 2025 20:00 #328103 by zz912
"make clean" - helped. Thank you.
Time to create page: 0.275 seconds
